Question: Jdm Front End Conversion
Old Nov 2, 2006 | 12:23 PM
TO_FIT_OR_NOT_TO_FIT's Avatar
Thumbs up Question: Jdm Front End Conversion
I was wondering if any1 who has done a front end conversion can post some pics and write up on the swap. I hear theres quite some modification to do to make the jdm front end to fit the usdm front end. Since its not a bolt on process can any of you show me/us "fit community" the light. Any help/pics/write up will b very appreciated.
Old Nov 2, 2006 | 12:29 PM
joe d's Avatar
Old Nov 2, 2006 | 02:13 PM
Originally Posted by joe d
I did use the search, and yes that post did help, but it wasn't a diy project. Im looking for a diy write up and a detail one, due to the modification to the rebars and radiator support. Thx for the fast response tho.
Old Nov 2, 2006 | 02:29 PM
outlawhonda's Avatar
Are you looking for information to determine wheather or not if you are capable to doing the swap?
Swap can be pretty easy if you have access to a welder and know how to use it. Basically take off everything on the front end(hood, fenders, bumpers, headlight, rebar and drill out the spot weld on the radiator support to remove it) Weld the JDM radiator support, bolt the JDM stuff back on and that's it. Oh and paint ofc.
I did mine first conversion on a DC2 and can't say I did a good job welding it..I learned how to weld from the 15mins video that came with the welder. I did do a much better job on my 2nd one tho.
Basically anyone body shop can do the swap, it's an everyday thing for those guys, I highly recommand going with your local shop unless you're like me
Old Nov 2, 2006 | 03:14 PM
Its not a question of able or not able to do the conversion myself. I know its been done, its the matter of modification to the parts on the usdm fit to make the front end fit. Yeah it'll b ez if u had the radiator support frame, just cuting and welding, but i heard peeps are doing it without it and just cutting into the usdm radiator support bar.
What i need is pics and written detail on where on or in the radiator support frame is cut/drilled/bolt/etc.
Yeah i would think a autobody is the best for this kind of work, but im the kind of person who wants to go the trail and error route...lol. Thx for the suggestion and info.
Old Nov 2, 2006 | 04:36 PM
Much better just to swap out the support IMO(factory fit and finish)
Hope you will find the answer you are looking for, good luck
Old Nov 2, 2006 | 08:10 PM
prizzom's Avatar
Im looking for a detailed conversion also. i figure how much it would cost for the entire conversion kit: (American Dollars)
JDM Fenders - $214.30
JDM Honda headlamp Assy - $736.64
JDM Honda Front Bumper - $700.93
JDM Radiator support - $205.37
Radiator support - $84.83
just for fun i threw in a OEM carbon fiber hood - $599.00
i dont know about shipping prices or painting prices. but the total is $1941.61 w/o carbon fiber hood and $2540.61 with the carbon fiber hood. tell me if im missing anything. here are the sites i got them from -
http://www.body-kitz.com/enter.html?...rget=d150.html
http://www.aj-racing.com/catalog/home.php?cat=155
what do you need for a rear tail light conversion?
Old Nov 2, 2006 | 08:36 PM
i believe ur missing the front rebar unless it is attach to ur radiator support, the support bars for the headlights. Other then that i think ur good to go.
Old Nov 2, 2006 | 08:44 PM
prizzom's Avatar
Oops, the one that is $84.83 is suppose to be the rebar. i never knew that you need a light mounts. I'll try to find out.
Old Nov 3, 2006 | 02:56 AM
yeah i think if u were to get the radiator support frame...it would put u back at lease 300 bux. There are these mounts that hold the lights just about the rebar and sits under the lights.
https://www.fitfreak.net/forums/showthread.php?t=4747
check that link out in page 2...3rd post of something...
Old Nov 3, 2006 | 08:32 PM
any1 out there who has done the front end, mind taking it all apart and doing a detail write up just for the community. Im sure we'll all appreciate it to the fullest.
invalid
Feb 21, 2018 07:16 PM
hogwylde
Dec 10, 2010 09:45 PM
09blackfit
Dec 10, 2009 08:11 AM
Spooling
Feb 27, 2009 03:01 AM
Bennet Pullen
Apr 20, 2007 05:41 PM
