Quote:
Originally Posted by RageOfFury
The rims I bought at Costco are black steel 15x6"/4x100 but I have no clue if they have the appropriate offset. I will go and write down the other numbers that are on the rim and maybe someone can figure out what they mean.
As for the tires, I bought 4 Michelin XICE 195/55R15 winter tires for my Fit Sport. They will be installed next week
Costco is good about making sure that you are satisfied. If they were able to look on the chart for fitment and it looked acceptible (even if it was a 2006 FIT/Jazz) it should be ok.
I would guess that the offset of the rims will not be a problem and the tires should fit the rim and your FIT OK.
It's easy to tell if all is well when you drive. The rim is not overly wide and neither is the tire so there should be ample clearance with any rim of offset about +42mm to +50mm. There may be no marking to help you know the actual offset.
