Fan control 1-3 out
Old 01-26-2010, 11:08 AM
alshead's Avatar
Fan control 1-3 out
Anyone have problems with the fan control? On one of our Fits (we have four in a delivery fleet), the first three levels stopped working on the fan control, but the fourth (highest) fan level is still working.
Any ideas? Haven't had a chance yet to check fuses, but seems they would all be on the same fuse?
Old 01-26-2010, 11:32 AM
mynameisphunk's Avatar
Sounds like a resistor on the blower motor is out. Very common problem on older water-cooled Volkswagens, and the fan setup on a Fit is no more complex than an 80's VW. This is common on other vehicles as well. Definitely a dealer issue.
Old 01-26-2010, 11:38 AM
Uncle Gary's Avatar
IIRC, there are a couple of threads here on this problem. As I recall, mynameis has the answer.
Old 01-26-2010, 12:37 PM
rhyneba's Avatar
Service bulletin 09-097 HVAC blower motor only works on high.
Needs a new blower motor transistor pack, if your VIN falls between 000001 AND 072640 it applies as long as the car is under warranty.
If someone wants me to send the pdf I will.
b
Old 01-26-2010, 12:46 PM
Fitcious's Avatar
so will it be a smart idea to let the dealer change it first before it breaks? will the dealer do that for us, if it falls between that vin #? i dont want to wait till warranty is over and it breaks.
Old 01-26-2010, 01:48 PM
clicq's Avatar
b
You are the man! I don't have this problem, but it's great that there's somebody that knows about all this stuff .
As an aside, here's a link to the service bulletin:
SB 09-097 HVAC blower motor only works on high speed
As I understand it, you can't have a service done just because it shows up in a service bulletin -- you actually have to be having the problem. Though rhyneba could probably clarify.
It does seem pretty easy and cheap to change the resistor pack though... but the SB also calls for the replacement of the blower motor, which isn't so cheap...
Old 01-26-2010, 01:57 PM
Snowboard4Life's Avatar
I had this issue with my Grand Prix a few years back (only highest blower setting worked). It was recommended to change both the resistor, as well as the blower motor. I changed only the resistor and everything worked fine after that. I think it's more of a convenience/precautionary measure to do both since you were already working in the area.
Old 01-26-2010, 03:26 PM
Steve244's Avatar
Service bulletin indicates it only Sazuka assembled fits.
Applies To: 2009 Fit – From VIN JHMGE8...9S000001 thru JHMGE8...9S072640
whew. heh.
Old 01-26-2010, 03:52 PM
rhyneba's Avatar
The condition must apply for the repair to be completed. And yes, they will replace the blower motor that caused the failure of the transistor pack. Because of the high frequency of failure on transistor packs I see on older Hondas I run my fan on the higher speed settings if I run it at all. The lower speeds generate more heat from resistance thus shortening it's life. Turned off my automatic locking for similar reasons.
Old 05-24-2011, 10:02 AM
wat's the TSB number for this? is it the 09-097 number? thanks
Old 05-25-2011, 09:56 PM
clicq's Avatar
Yes, it's 09-097.
Old 05-26-2011, 11:21 AM
This is a common design for many makes and models. No reason to limit yourself to your desired fan speed and be uncomfortable. If the resistor pack blows just replace it for $15. From Honda parts fiche it looks to be easily accessible and 5 minute job tops. Fan motor will not need to be replaced 99% of the time for normal failure of the resistor. Early life failures (caused by motor) will be covered under warranty and motor replaced per TSB.
_
Old 05-26-2011, 07:24 PM
SSMTEN's Avatar
I had this happen 2 weeks ago. Showed up at the dealer, told them 1-3 didnt work. had it fixed the next day first thing in the morning in less than 1 hour. Didnt have to do anything other than point to the problem and hand them the keys..
Old 05-26-2011, 08:21 PM
M.R.fit's Avatar
Anybody got the part number for the relay? Mine crapped the bed this morning.
Old 05-27-2011, 09:48 AM
rla217@'s Avatar
+1, mine stopped working about a year ago, dealer knew about the problem & fixed in less than an hour as well. No problem since then.
Old 07-06-2011, 09:09 AM
jdufford's Avatar
Mine went out, and I change the resistor myself. It was a simple enough repair. It worked like gangbusters, for about 30 minutes. Now it is doing it again.
Old 07-06-2011, 09:50 AM
AugeesFit's Avatar
Jdufford, if your car still under warranty bring it back to the dealer. My 09 had the same issue its not the resistor its the HVAC Blower. I took it to MW in Barrington and it took 2 days. They have to order the part and install it the next day and pick up later in the afternoon.
Old 07-06-2011, 11:08 AM
jdufford's Avatar
Thanks Augee, I drive by that place almost daily, but my car is out of warranty. My big concern is if I buy another fan, whats to say the new one doesn't do the same thing, then I am out about 200.00. I'm worried Honda hasn't done anything or changed the design of the fan at all to correct the problem.
Old 07-06-2011, 11:32 AM
Steve244's Avatar
Here is the link to the service bulletin on another site, Scribd. (not sure if you can access the link above, it doesn't let me.)
applies to 2009Fit from VIN JHMGE8...9S000001 thru JHMGE8... 9S072640
(note the letter "S"; this only applies to Fits assembled at the Sazuka plant)
Symptom
The HVAC blower motor only works on high speed.
Probable Cause
Excessive current draw from the HVAC blower motor causes the blower resistor to fail.
Corrective action
Replace the HVAC blower motor and the blower resistor.
If your Fit falls within the range of VINs, given that you've already blown a 2nd resistor set, I think it's a near certainty the problem rests with the blower motor.
Edit:
From the bulletin: "Any repair performed after warranty may be eligible for goodwill consideration." You may not have to pay anything.
Old 07-06-2011, 11:40 AM
malraux's Avatar
Given that there's a TSB about the problem, and it isn't nearly as big a problem with the later years, its a good guess that they changed something to make it less of a problem.
Quick Reply: Fan control 1-3 out
