View Single Post
  #55 (permalink)
Old 11-09-2006, 11:09 AM
wyy183 wyy183 is offline
Frequent FitFreak Poster
wyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to livewyy183 relies on Rep Points to live
Quote:
Originally Posted by aqua
Hi guys !
(sorry for my bad English, I'm a french-canadian...)
I have the Sport version of the Fit and I want to know if you have the same problem than I. When there are 3 or 4 of us in my car, the back tires touch the wing in the back when I'm on the road with bump (even small bump).
At the garage, they told me that it might be because I have winter tires (Toyo 195/55R15).
I don't know if this problem happens on the stock tire because i got my car with the Toyo winter tires already on it.
Do you guys that have winter tires have experienced the same problem than I ?
Simon
First, your English is better that most!!
Second, your tires are the correct size; however, the offset on the wheels is probably wrong. The correct offset for a Honda Fit is +55mm. If the dealer installed the wrong wheels, then they need to fix it.
Good luck!
__________________
David
'07 Fit Sport, red, AT
