View Single Post
  #12 (permalink)
Old 11-21-2006, 12:42 PM
kps kps is offline
Honda Fit Forums Moderator
kps will become famous soon enough
Quote:
Originally Posted by b17gsr
I'm not sure how accurate the scangauge is for fuel economy readings (I've yet to see an on board computer that was accurate)
Over a full tank, it's pretty good; it's not worse than using the odometer, which I know is off (but, until I buy or borrow a GPS, I don't know by exactly how much).
Quote:
but can you post your actual litres used vs kms driven after your next fill up?
My most recent tank was 35L (by the pump) over 585km (by the odometer) for 5.98L/100km or 39.3mpusg. (By the way, you can actually type 35L over 585km in mpg into a Google search box and get the answer.) My total since October is 155.3L over 2526.7km for 6.15L/100km or 38.3mpusg. I suspect that the figure corrected for true distance would be about 1mpusg lower.
Quote:
Stating mileage figures for a 5km drive isn't the way people state their fuel economy.
That was a relative comparison to indicate the effect of a block heater. Obviously other conditions are never identical between any two trips but those values are reasonably typical.
