Quote:
Originally Posted by wk406
I tried last night, after struggled with the clips, got the cover off but couldn't loosen the screws so I gave up. So you don't have to take the whole unit out but just the lower cover?
Thanks
Right, just the lower cover. Use a flashlight so you can see the clip and wires. On the right side (looking at it) there is are large black and yellow lines which I think are cables. That's NOT what you're after.
The wires are very small and the clip is easy to miss so a flashlight helps a lot.
