Check Engine light is on
Old 11-06-2011, 08:00 PM
peacemaker1911's Avatar
This morning my check engine light appeared on my 2008 Fit.
It has 65k miles and well maintained at Honda dealership. I was going to take it in tomorrow to change oil because it was on 10% but the light came on today so I went to jiffy lube to change it. Engine light is still on, and coded
Definition:
* VTEC Oil pressure swith circuit low voltage
Probable Cause
* Check Oil level and pressure
* Open or Short circuit condition
* Failed VTEC Pressure Switch
I got these at AutoZone cause dealership was closed.
My question is, whats do they mean and do they sound expensive????
Old 11-07-2011, 01:22 PM
Dealer said $390 to fix. He would not give me any details to whar part it was other than " P2647 Faulty VTEC Solenoid / switch assembly" Is he ordering the whole assembly or just the switch?
He said the thing switch was stuck on the "ON" position.
Switch
Assembly
Old 11-07-2011, 01:32 PM
malraux's Avatar
Did they run through the diagnostics or just tell you that based on the code?
Old 11-07-2011, 02:02 PM
Based on the code I guess. They put it in the stall, and hooked up the computer, thats it.
I can get the switch from $15-$55, removing and replacing dont look hard. Now the assembly I would probably let them do.
Old 11-07-2011, 02:18 PM
Steve244's Avatar
If it were me, I'd clear the code and see if it came back before having it fixed. Might be a transient that won't repeat.
edit: although "stuck on the on position" doesn't sound transient.
Old 11-08-2011, 01:21 PM
wistlo's Avatar
good way to read/clear codes
If you need to clear the codes, don't have a reader, and have an Android smartphone, this is a good combination:
Android app: Torque — OBD2 Performance and Diagnostics for your Vehicle
OBD-II Bluetooth interface: Amazon.com: PLX Devices Kiwi Bluetooth: Automotive
You can read the OBD data in real time and and upload to a server, as well.
Old 11-08-2011, 01:45 PM
malraux's Avatar
Glancing at the service manual for that DTC, it could be either the switch or the whole assembly. It depends on what the computer told them.
Old 11-22-2011, 02:38 PM
Where is the unit located ? I cannot see it anywhere.
Old 01-16-2012, 06:05 PM
Everyone was saying it was on the passengers side, but it ened up being on the drivers side of the block. Took about 5 minutes to change the part and about $75 for the part including the o-ring. took about half a day for my light to come off. VTEC KICKED IN YO!!!!
Old 01-16-2012, 06:46 PM
+++bingo+++
Old 01-21-2012, 05:20 PM
clemsonteg's Avatar
Good info to have, always comes in handy if it happens to you
Old 01-21-2012, 05:58 PM
einstein77's Avatar
Too bad Honda charges so much for such a fix, but that's their life blood.
mattpuchlerz
30
05-12-2017 03:31 PM
Number18
12-04-2015 01:26 AM
oldblue
06-13-2014 07:39 PM
Skytraveler
06-25-2010 09:03 AM
Randy Brick MacKenna
05-09-2005 01:49 PM
Quick Reply: Check Engine light is on
