A/C Button doesn't engage
Old 09-03-2009, 10:23 AM
grassmunk's Avatar
So this morning my wife told me it was already cold enough so turn off the A/C. I hit the button and off it went. No problems. Then a little while later after I dropped her off at work I try to turn it back on and it won't engage.
When I press the button down the switch lights up, it makes the click noise but when I let go the light turns off. Basically it doesn't engage. The defrost button works fine. When I got to work I tried playing with it a little and if I hold it in about 1/4 inch the A/C engages and I get cold air.
This is on a 2007 Fit with 6,000 miles. Would this be covered under warranty? Or is this something I can easily/quickly fix myself?
Old 09-03-2009, 10:49 AM
spreadhead's Avatar
If you haven't reached 3 yrs. since delivery it should be covered.
Old 09-03-2009, 11:24 AM
grassmunk's Avatar
Well, turns out my wife got the car 9/4/2006. So tomorrow would be the 3 year mark. Is this something that is expensive to fix?
Old 09-04-2009, 08:08 PM
Carbuff2's Avatar
Our '07 Fit's A/C switch was replaced under warranty for the same reason.
If it's this switch the price is less than $25 USD:
35500-SLN-A01ZC 1 SWITCH ASSY., RR. DEFOGGER & AIR CONDITIONER 1
List $ 29.78 Sell $ 22.16
(This from HondaPartsDeals.com)
HondaPartsDeals.com
Saccucci Honda
1350 West Main Rd.
Middletown, RI 02842
(877)5-HONDA-5
Email: info@HondaPartsDeals.com
Old 12-16-2009, 01:38 PM
sixtattz's Avatar
Tips on how to replace. I have the same problem
Old 03-10-2010, 11:17 PM
Riceman's Avatar
a/c switch
I have a coworker that is having this problem. Has anyone replaced this switch that can give some steps, pics, help, etc? My coworker is an older single female that bought her 07 Fit in July of 06 on my advice. I'm hoping that this is a simple fix that I might be able to help her with and save her some money. Thanks.
David - Dallas, TX
07' tw Fit Sport
10' Nissan Cube SL
00' Nissan Xterra
91' Nissan NX2000
Old 09-20-2010, 08:09 PM
JeremyR's Avatar
My '07 has a similar issue, except that the A/C won't turn off. Given that the temperatures have been in the 90's, this isn't a bad thing right now... but I'll eventually want to turn it off!
The switch itself is probably easy enough to replace, but I'm not sure about the surrounding trim, which will probably have to be removed first. But first I'll just try some electrical contact cleaner...
Old 01-14-2011, 03:10 AM
clay7160's Avatar
my 09 won't turn off either, guess back to the dealer
Old 01-14-2011, 10:45 AM
chrisng's Avatar
can you hear the compressor acutally engaging? this happened on my civic and a rock had punctured the line. you can checked the freon levels in the system, and make sure that the ac compressor is engaging when you defrost i believe the compressor turns on automatically with the defrost mode.
Old 12-02-2011, 04:03 PM
Danny0707's Avatar
This is happening to me as well. What i have been doing is flipping re-circulation switch allowing air from outside to come in back and forth until it turns on. Hope this can temp solve the problem. I think it helps the AC switch make contact and engages it.
Old 07-19-2013, 07:15 PM
plreming's Avatar
This is the exact problem that I just had with my 2009 Honda Fit. The air conditioning was working this morning, then stopped. It works if you hold the button down (and the light comes on). But it you release the button, the light goes off, and the compressor no longer engages (and therefore, the air that blows is not cold).
What solved your problem?
Thanks!
Old 07-20-2013, 05:53 AM
Black3sr's Avatar
Thanks!
Sounds like the switch is faulty. No big deal to pull the surrounding panel off to get at it.
Old 02-20-2016, 03:53 PM
HFit2010's Avatar
A/C button doesn't stay engaged and gets hot
I have a 2010 Honda Fit Sport with 106000 miles. Yesterday I was parked with the car on and the a/c on. All of a sudden, the a/c button turned off on its own. I noticed that the button was hot to the touch. I tried pushing it in but it would not stay pressed in by itself. As long as I held the button in the a/c worked fine, but if I let it go, the a/c stopped working. So I read this forum and I figured it out without going to the shop or taking the whole dashboard apart. Take a flathead screw driver and place it below the A/C button and pop out the A/C button carefully. You'll see the little rectangle assembly where it's connected to the wires. If the button pops out and not the rectangle assembly, you may have to gently pull the assembly out with a pair of pliers. Disconnect the assembly from the wires and replace it. I tried local autopart stores but no luck. Had to go to the Honda dealer. I asked for an A/C switch. Cost me $30 with the tax. Works great! Hope this helps you out!
Attached Thumbnails A/C Button doesn't engage-80-20160220_145922_5beb4134e636603978cad8e1bef1670c6f511c9a.jpg
Old 02-21-2016, 08:52 AM
Black3sr's Avatar
Well done HFit. Saves a lot of work.
I have filed in my DIY bookmarks
Old 03-09-2018, 09:30 PM
honda_fit_2009's Avatar
You're a god. I got a genuine Honda A/C button off eBay for $25, was able to pull the old one out using a flat head screw driver (my button was eternally stuck ON). The button popped off, then I pulled the rest of it out using pliers. I put the glove box down and reached pliers in to grab the wires, then pressed the new button into the plug. Works perfectly now. All that without spending an hour to take the dash apart. thank you!
Old 08-08-2020, 12:46 AM
Redeyedspy's Avatar
Saved over $300!
Still helping people in 2020! This tip saved me over $300!
Old 05-22-2022, 09:00 PM
joblackk4949's Avatar
Or you can do this and run this for another 100,000 miles. I refuse to give these idiots 500% markup when this button can't coast most then $8 to make. Called one of our deepshits at Honda. They wanted $60 for this button. I think not.
fitchet
05-20-2018 10:27 PM
fithawk
09-11-2015 02:43 AM
Blaw
01-16-2008 09:02 PM
TOPHER1
12-28-2006 10:39 PM
Quick Reply: A/C Button doesn't engage
