Sponsored by:
Sponsored by: CARiD
Remote (auto) Starter for the Fit?
Old Oct 13, 2006 | 10:59 AM
dealspecialist's Avatar
Question Remote (auto) Starter for the Fit?
Anyone get a remote starter installed on their Fit? I'm picking up my Vivid Blue Pearl Sport Auto Fit next Saturday and I'm already starting to think about what I plan on putting in it. I always wanted to have a remote starter in my car!!!
Any suggestions on which ones to get, which ones are compatible. I don't really want to carry around more than one remote so I would prefer if it worked with the factory keyless entry.
dealspecialist
Old Oct 15, 2006 | 02:36 PM
MirrorWorks's Avatar
I've heard Compustar systems are bomb if you can find an experienced installer that works with them. You can find awesome systems online for like $200 on froogle.com too.
tre
Old Oct 16, 2006 | 09:47 AM
tre
That's another question too. How do I find an experienced installer.? I heard you could really damage your car if the you don't know what you're doing and that's why I'm not doing it myself.
Are all Compustar systems good? As long as it won't hurt my car and won't break I don't need anything fancy.
Old Oct 24, 2006 | 03:25 PM
edstroyer's Avatar
dealspecialist
Try have an authorized Honda dealer install the remote starter (If Possible). They love blaming third party installations for anything that goes wrong in your car. You don't want to void the warranty of your Fit.
Old Oct 24, 2006 | 04:02 PM
Jimmy101's Avatar
Compustar!!!
Find an authorized dealer, they are all certified by compustar to install them.
Wait until the mid march, they are coming out with a new
updated products, with 6000Ft range.
http://compustar.org
Old Dec 6, 2006 | 04:05 PM
Wave's Avatar
I asked this question when I first picked up my car too.
My local BJ's Wholesale Club had a DIY kit for under $100 - I never did find out if it would work or not...something about the chip in the Honda Key or something like that. I still want one.
I had a remote start installed in my 03 Nissan Xterra SE-S/C by Best Buy - great for those freezing cold mornings when the vehicle is covered by 6+ inches of snow!
Old Dec 7, 2006 | 12:47 AM
gimme's Avatar
Master FitFreaker
well. as far as installers. where are you located? my wife's cousin does this for a living. did it on my wife's old CR-V. worked great
Old Dec 11, 2006 | 08:44 PM
aallbbeerrtttttt's Avatar
well if you want to do it, you're going to need to remove the immobilizer that is within the ecu and the key of the fit, otherwise, it wont work
Old Dec 11, 2006 | 09:03 PM
etong's Avatar
not sure about compustar for a fit but they just installed a bypass in my rsx, no need to remove anything, didn't even need to give up my spare key. your stock immoblizer still works should you decided to put the compustar in valet mode (which turns the compustar security system off)
Old Dec 12, 2006 | 02:46 PM
spoonek4's Avatar
I'm using compustar also with the 1way FM alarm. I like it so far.
Old Dec 12, 2006 | 11:17 PM
TeamEMC's Avatar
There are Immobilzer bypass kits on the market for like 35 bucks that bybass the transponder only during remote starting.... I just installed on in my MT Fit. worked like a champ. Very easy to set up 1 jumper. turn the key on move the jumper from position A to position B. done
Old Dec 13, 2006 | 08:55 AM
etong's Avatar
i'm curious to know if the bypass will actually weaken the stock security since you are able to start the car without a coded key making it possible for someone to start your car with the right code
Old Dec 13, 2006 | 12:58 PM
TeamEMC's Avatar
Well your bypass is activated by the alarm, so if you don't remote start it then the stock immobilizer is still active.
Old Dec 18, 2006 | 07:36 PM
xCHRISx's Avatar
i had the viper/hornet alarm installed as a dealer option at the time of sale. more than happy with it. warm ups in the jersey cold weather is great. car warms up rather quickly, so only need to auto start the car 5-7 minutes before getting in. alarm offers peice of mind. only regret is that they installed the red alarm light in the blank plate where the jdm coin slot goes. i'll be looking to reroute the wires to the oem light in the gauge cluster so i can install the coin slot later.
Old Jan 22, 2007 | 05:26 PM
Spinkman's Avatar
My understanding of the Remote start and the immobilizer is:
1)the immobilizer is bypassed to allow a remote start, alarm is still active
2)deactiveate the alarm to gain entry into the vehicle
3)the key with the factory immobilizer chip must be present, in the ignition and turned to the 'on' position for the car to be driven
4)If there is no key present and the car is attempted to be driven then the car will shut off.
Please correct me if I am wrong.
Compustar 2way systems are great, many many functions. even a timer to tell you how long you car has been warming up for and if there were any problems with the start. (like if you left it in gear or it failed to start)
I will be getting a compustar system for my FIT in the spring as I opted out of remote start and keyless entry for my fit from honda. (the compustar system would only be a little bit more$$$ and worth every cent.)
just my opinion.
Old Jan 22, 2007 | 06:31 PM
bestfit's Avatar
Valet 561R is a good chice.. i have it on my 02 Honda Odyssey and it works great...
Old Jan 22, 2007 | 10:49 PM
etong's Avatar
just my opinion.
you can get remote start function from honda? that's news to me
regards compustar, it's pretty much impossible to leave the car in gear and auto-start it because you have to exit the vehicle while it's still running. Also, sometimes you will only get 1 way signal on the pager if your car is too far off.
Old Jan 24, 2007 | 12:38 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
hi etong! i'm on crsx too
theres several ways to have the remote start. heres 2:
-compustar-with all the nifty features and security
-just a plain add-on remote start module that will remote start your car via factory remote.
either option, they'll need the DEI immobilizer bypass module. it doesnt render the car "vulnerable" at all. If a thief really wanted to steal your car, they'll tow it.
maybe one of these days, i'll do a writeup for a DIY on remote start/alarm install using Compustar and/or add-on.
Old Jan 24, 2007 | 12:55 PM
gimme's Avatar
Master FitFreaker
please move to california so you can install this on my Pilot
Old Jan 24, 2007 | 01:20 PM
03DSM-RSX's Avatar
its not that hard really. there are guides on google that if you searchhard enough, theres wire diagrams showing the location of all the wires you need. (ie. door trigger, horn, 12v ignition source, etc)
if you know how to read instructions, cut/strip wires, know + and -, you're good to go. i recommend heat shrinking connections but its not always possible. so wire tape comes in handy too. i am against crimping wires. wrap-tie-tape works better. just practice on your method of taping. 3M wire tape is good tape, quality of wire tape matters as well.
