I love this manual shifter. I've driven a mightymax truck, s2000, civic 97, CRX, and this one is VERY easy to drive. The only problem you might encounter is you might stall a lot. I think the fit is very weak below 900RPM. The cluthc pedal is light and doesn't feel like you're leg pressing weights or anything. The shifter is smooth and does a comfy "click" when it goes in gear. The shifter is also very light. Don't need force to pop it in.
