View Single Post
  #24 (permalink)
Old 12-14-2006, 03:11 AM
AJ PwR Jr.'s Avatar
AJ PwR Jr. AJ PwR Jr. is offline
Platinum Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
Sorry, I have been trying to get the dyno done ealier but due to shitty weather (SNOW & Heavy rain) so I wasn't able to do it any sooner. And NOW the dyno is done and I would like to announce the results to you all
Dyno 1 - Bone stock
Dyno 12 - T1R Intake + T1R Crank pulley +T1R 50S Cat-back exhaust
Dyno 19 - T1R Intake + T1R Crank pulley +T1R 50S Cat-back exhaust + T1R HEADER !!!!
Here the gains from DYNO 19 vs DYNO 12 :
3000rpm+1whp / +1 lbs
3500rpm+2whp / +2.5 lbs
4000rpm+4whp / +4.6 lbs
4500rpm+3.8whp / +3.8 lbs
5000rpm+2.6whp / +2.2 lbs
5500rpm+2.8whp / +3 lbs
6000rpm+1.07whp / +1.2 lbs
6500rpm+ 0whp / + 0 lbs
Here's DYNO 1 vs DYNO 19 :
3000rpm+3.5whp / +4.2 lbs
3500rpm +6.8whp / +8.2 lbs
4000rpm +8.3whp / +8.7 lbs
4500rpm+8.8whp / +8.5 lbs
5000rpm+10.1whp / +10 lbs
5500rpm +12.9whp / +8 lbs
6000rpm+13.9whp / +11.8 lbs
6500rpm+ 14.6whp / + 11.3 lbs
The 38mm piping on the header did biger difference. When we dynoed the 32mm header, the result was same as stock and we only gained a little bit of torque. After we installed the 38mm, we noticed a difference on the dyno right away.
Thanks
Ben
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
