Tanabe Gf210s photos, questions, answers
Old Dec 19, 2006 | 11:44 PM
  #61
HFit USA's Avatar
Frequent FitFreak Poster
awsome good info yo, now we know what to get re-setup at.
Old Dec 20, 2006 | 01:32 AM
  #62
Research Monkey's Avatar
Forgot to mention that he does the alignments with you in the car.
Old Dec 20, 2006 | 07:36 AM
  #63
CarDemon's Avatar
Senior Member
Thumbs up
Never heard or thought of that as a factor since I'll be driving mine alone 90% of the time. Makes alot of sense though!!!
Old Dec 20, 2006 | 10:54 AM
  #64
quangalang's Avatar
arent the OEM camber bolts just made skinnier in diameter so theres more play in the strut so you can move it around til you get the camber just right?
Old Dec 20, 2006 | 12:43 PM
  #65
They are exactly the same size as the stock one on the car. Usually a camber bolt will have a small hump right above the threads so when you rotate the bolt it will move the hub for +/- camber.
Old Dec 20, 2006 | 02:07 PM
  #66
quangalang's Avatar
then where can we get some??
Old Dec 20, 2006 | 02:17 PM
  #67
I'd like to know as well... but seeing as how i just got an alignment, i dont see any point in dumping another 20-30 bucks into bolts then another 50 on the alignment for another -.5 - -1 degree more camber
David
Old Dec 20, 2006 | 05:21 PM
  #68
JDM_DOHC_SiR's Avatar
I'm sure if you could find someone to sorce the JDM front strut mount bolts & nuts ...since they are smaller in DIA. vice the USDM ones you could use them for setting more camber in the front...??? give me a day or two and I'll see if I can post the part # for you guys
Old Dec 21, 2006 | 12:35 AM
  #69
outlawhonda's Avatar
Below is straight out of Honda's Interactive Network, the part# is probably correct but wrong part in the wrong package, happens all the time. I will check my service manual tomorrow and see what it says. If those bolts are not on your car, I would return them and just tell the parts deparment what happened, I'm positive they can verify that Honda made a mistake.
Old Dec 21, 2006 | 02:07 AM
  #70
Then this happened twice because i bought 2 of them!
-David
Old Dec 21, 2006 | 05:52 PM
  #71
azkikersfit's Avatar
nice stance sweet ride
wat size of rims and tyres u got?
cos i wanna change from my NF210 to a DF210 for a lower stance
Old Dec 21, 2006 | 06:10 PM
  #72
16x7 +40 w/ 205/45 Falken tires
Old Jan 4, 2007 | 06:08 PM
  #73
i wanna get a the DFs but i got a JDM GD1, is there any difference between JDM and USDM tanabe springs? will there be fitment issues or will it be the same fitting for both JDM and USDM??
Old Jan 4, 2007 | 06:35 PM
  #74
hi
is there any difference between JDM and USDM fitting for the Tanabe Lowering springs?? cos i wanna change from NF210 to DF210, i have a JDM 2004 Honda Jazz and im currently on my Tanabe NF from Japan,
will i have fitting issues if i get Tanabe USDM and put em on my JDM Jazz
Old Jan 5, 2007 | 12:16 AM
  #75
Paulo107's Avatar
i wander if i should get mine aligned since mine are dropped on skunk2
i would have to look at any alignment place or fine someone that does it for lowered vehicles
Old Jan 5, 2007 | 01:19 AM
  #76
SSM0423's Avatar
Some are just skinnier which would allow you to more the strut in/out to get more camber adj.
Some are "eccentrics" which would have the small-hump; so when you rotate it, it'll change cam/caster...
Which one do you need?
Old Jan 27, 2007 | 01:48 AM
  #77
hiram's Avatar
where to buy tanabe springs??
hey all, first post here. im getting my fit next week(BOM) and i cant wait. but im new to these forums and i dont really know where to get parts(i drove a scion tC before which got totaled). can someone please tell me where i can get the tanabe springs? both the GF and the DF?? thanks in advance.
Old Jan 27, 2007 | 01:55 AM
  #78
aallbbeerrtttttt's Avatar
Old Jan 27, 2007 | 12:53 PM
  #79
hiram's Avatar
will these fit my 07???
Old Jan 28, 2007 | 02:04 PM
  #80
hiram's Avatar
Tanabe DF210 on Fit Sport anyone???
planning on getting these for my ride when it comes in next week. but the only pics ive seen here are not on sport models. wanted to see how the front lip stood off the ground. pictures would be appreciated as well as feedback. thanks in advance.
