Can you replace hubcaps yourself?
Old 06-19-2012, 11:00 AM
User12's Avatar
How hard is it to replace the hubs on the Fit? I am looking to get a base Honda fit, but just hate the lame stock hubcaps it has. But I don't want to spend 2 grand extra just to upgrade to the Sport trim just for aesthetics. Would the dealer do that for me or what??
Old 06-19-2012, 11:09 AM
MNfit's Avatar
what? if you dont like the wheels you can have a new set for pretty cheap. I would say $1000 or less. Even cheaper if you find a used set someone is selling
Old 06-19-2012, 11:13 AM
User12's Avatar
wow I thought it'd be cheaper than that.
Old 06-19-2012, 11:20 AM
low trq's Avatar
Take the hub caps off and roll on steelies.
Old 06-19-2012, 11:51 AM
Theos92vr4's Avatar
go to discount tire .com. I got a full set of wheels and tires and lugnuts mounted and balanced for $870. Brand new, 16x7 wheels. They often have wheels on there depending what size you want for less than $110 a wheel!oh, and shipping is free!
Old 06-19-2012, 01:05 PM
msbxiv's Avatar
I found some 2003 15" civic alloy rims on craigslist for $225, then had the TPMS sensors and Dunlops mounted/balanced to the used alloys for $140. TPMS worked without reprogramming.
Old 06-19-2012, 01:11 PM
msbxiv's Avatar
Make sure to get the little 56.1mm chrome center caps from a civic if you do this.
Old 06-19-2012, 01:14 PM
low trq's Avatar
I like it!
Old 06-20-2012, 03:08 AM
doctordoom's Avatar
Supervillain
I think User12 was asking about getting a new set of hubcaps, not a new set of wheels altogether.
Just go to Pep Boys or look around online for hubcaps or hubcap covers. You can probably find a set for $100. New wheels would be nicer, but if it's what you're looking for, yea hubcaps are a LOT cheaper than wheels. You should be able to just pop them off and pop the new ones on.
Old 06-20-2012, 05:17 AM
Black3sr's Avatar
I put these plastic ones on my winter wheels the first winter. Just threw them out. They were about $40.
My winter wheels painted and Civic center caps
I now have them power coated.
Old 06-20-2012, 12:02 PM
msbxiv's Avatar
You're right, and I totally got that which is why I posted the link to the picture of the steelies and the civic center caps as well as the option to craigslist some used wheels--it's just that sometimes new-to-you wheels are not that much more $$ than nice wheel covers. I'm just not a fan of full on hubcaps.
Old 06-20-2012, 12:20 PM
Wanderer.'s Avatar
Anyone know if those Civic centercaps fit on the stock Fit steelies properly?
I'm not really a fan of the Fit steelies weird asymetrical hole pattern (did they do that to make it easier to balance without weights?) but i'm REALLY not a fan of full on hubcaps either, so I may respray the steelies and run those centercaps instead.
Old 06-20-2012, 12:36 PM
msbxiv's Avatar
The 56.1mm civic chrome center caps fit perfectly on the Fit's black steelies. Just line them up and give them a whack with the palm of your hand (or a rubber mallet) to seat them.
Old 06-20-2012, 12:43 PM
Wanderer.'s Avatar
Thanks msbxiv, I guess you have first hand experience since you've got a 91 wagon and a 12 base, i'm sure you swapped them over out of curiousity, I know I would LOL.
Old 06-20-2012, 12:50 PM
msbxiv's Avatar
Exactly--my original intention was to use the center caps on my steelies but then I found the alloys for a price to good to pass up. I'll still use the steelies for winter tires like Black3sr.
Hey Black3sr, which winter tires do you use (apologies to OP for hijacking the thread)?
Old 04-10-2013, 08:02 PM
animated's Avatar
I know this is an older thread... but where can you get those caps? I'm not loving the hubcaps on my 2013 base FIT.
Old 04-10-2013, 08:15 PM
MPA's Avatar
MPA
MPA is offline
EBay - just search for 1988-2007 civic crx center caps. They also have all chrome without the black.
I picked up a set for my '13 base, but haven't put them on yet as my steel wheels are kinda nasty. Not sure if I'm going to respray them semi-flat black or paint them silver like they used to come from the factory in the '90s
Old 04-10-2013, 09:00 PM
animated's Avatar
Hmmmm, thanks for the reply! I checked there, but the black ones only have 1 available I have a black fit, so I'm kind of set on the black caps.
Old 04-10-2013, 09:47 PM
animated's Avatar
Old 04-10-2013, 09:53 PM
hogwylde's Avatar
MNfit meant for a new set of wheels NOT hubcaps.
Quick Reply: Can you replace hubcaps yourself?
