New Civic: Flat spots on tires return after 24-48 hours?
Old May 4, 2005 | 11:16 AM
Nobody
Guest
Posts: n/a
I got a new Civic 3 weeks ago and have had various vibration and steering
wheel shake issues. All of the problems have been corrected (mostly by
swapping wheels with another car) except one.
The dealer gave me a set of four new wheels from another car which seemed
great until I rotated them and found a shake (one wheel looked like it had
an uneven mounting surface). I had them put the good pair of the new
wheels on the rear and my original rear wheels on the front.
All is great except for one thing: When the car sits for 24-48 hours,
wicked flat spots return on the front wheels (original rear wheels). I
know it's these wheels because it first happened when the dealer put these
back on. If you drive it for 40-50 miles, it will go away (actually, when
I overinflated them and it smoothed out in 4-5 miles). Let it sit for
another 24-48 and it will return. I swear I even feel a litte something
when it only sits overnight that does go away after a few miles of highway
driving.
These wheels have nearly 1200 miles on them...will this go away or should I
push for new tires?
Note that it is 15-20 degrees here in NY pretty much night and day.
FanJet
Guest
Posts: n/a
Re: New Civic: Flat spots on tires return after 24-48 hours?
> steering wheel shake issues. All of the problems have been corrected
> (mostly by swapping wheels with another car) except one.
> seemed great until I rotated them and found a shake (one wheel looked
> like it had an uneven mounting surface). I had them put the good
> pair of the new wheels on the rear and my original rear wheels on the
> front.
> I know it's these wheels because it first happened when the dealer
> put these back on. If you drive it for 40-50 miles, it will go away
> (actually, when I overinflated them and it smoothed out in 4-5
> miles). Let it sit for another 24-48 and it will return. I swear I
> even feel a litte something when it only sits overnight that does go
> away after a few miles of highway driving.
> should I push for new tires?
I drive my car when it -10 to -15 F with no problems. You've got a new car.
This a dealer problem not yours. Ask them to take care of it.
TomP
Guest
Posts: n/a
Tires are not a dealer problem. Tires are warranted by the manufacturer of the
TIRE...
> > front.
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
ravelation
Guest
Posts: n/a
>the car sits for 24-48 hours, wicked flat
>rear wheels).
If these are low profile tires, that could contribute to the problem. I
know Bridgestone Potenzas have been accused of this behavior a lot.
I think flat spotting comes from the tires, no?
FanJet
Guest
Posts: n/a
> manufacturer of the TIRE...
>>> corrected (mostly by swapping wheels with another car) except one.
>>> looked like it had an uneven mounting surface). I had them put the
>>> good pair of the new wheels on the rear and my original rear wheels
>>> on the front.
>>> hours, wicked flat spots return on the front wheels (original rear
>>> wheels). I know it's these wheels because it first happened when
>>> the dealer put these back on. If you drive it for 40-50 miles, it
>>> will go away (actually, when I overinflated them and it smoothed
>>> out in 4-5 miles). Let it sit for another 24-48 and it will
>>> return. I swear I even feel a litte something when it only sits
>>> overnight that does go away after a few miles of highway driving.
>> new car. This a dealer problem not yours. Ask them to take care of
>> it.
Any self respecting *dealer* will take care of *any* problem on a 3 week old
car and stop top posting!
Dave D
Guest
Posts: n/a
Did you check your tire pressure afte the car has set for a while?
Dave
"Nobody" <nobody@nowhere.com> wrote in message
news:Xns960FABC55D121nononononon@140.99.99.130...
> driving.
> I
> push for new tires?
TomP
Guest
Posts: n/a
Hey FanJet,
You're right a dealer should take care of it; but my statement still stands
correct.
With regard to top posting... Tough. You don't like it put me in your "dick
head" file, as I will do for you, if you continue...
> >>> on the front.
> >> it.
Tp,
-------- __o
Kelly
Guest
Posts: n/a
Re: New Civic: Flat spots on Bridgestone Potenzas
I just bought a Y2K Accord that came with new Potenzas on it. They
flatspot after only a few hours of driveway time. It's been reasonably
mild (20's) here at night. It's been 25 years since I've had this sort
of thing happen. That was Wisconsin, in the dead of winter, on bias-ply
tires.
Kevin McMurtrie
Guest
Posts: n/a
In article <Xns960FABC55D121nononononon@140.99.99.130>,
> driving.
> push for new tires?
I've had that happen with Bridgestone and Yokohama tires. It's very
annoying and distracting on Silicon Valley highways where 75-80 MPH is
typical.
The best tires I ever had on a Civic were the Michelin HydroEdge.
They're sloppy in cornering but they grip like duct tape even in the
rain. Also the quietest and best balanced at high speeds that I've ever
seen. They're pricey, though.
I unfortunately put them on my 97 Civic right before the car wore out.
Doh!
Sparky Spartacus
Guest
Posts: n/a
>>driving.
>>push for new tires?
> typical.
Doesn't it go away once the tires are warmed up?
Kevin McMurtrie
Guest
Posts: n/a
In article <Nra0e.7007$Lp7.6525@fe09.lga>,
> >>driving.
> >>push for new tires?
> > typical.
It sometimes took an hour or two on the bad tires that I had, but maybe
only 10 miles if lucky. Yeah, I checked the brake calipers, tire
pressure, lugnut torque, rim to hub contact surfaces, cleaned tar off
the rims, checked the wheel alignment, had the tires balanced
periodically, and checked for uneven tire mounting. Whether or not it
happened depended only on the tire brand.
Lightweight alloy wheels seem to amplify the problem. Maybe Nobody has
the HX.
Nobody
Guest
Posts: n/a
Kevin McMurtrie <mcmurtri@dslextreme.com> wrote in
news:mcmurtri-86ABF4.22432923032005@corp-radius.supernews.com:
>> >>on the front.
>> > very annoying and distracting on Silicon Valley highways where
>> > 75-80 MPH is typical.
> maybe only 10 miles if lucky. Yeah, I checked the brake calipers,
> tire pressure, lugnut torque, rim to hub contact surfaces, cleaned tar
> off the rims, checked the wheel alignment, had the tires balanced
> has the HX.
Nope, EX SE
Old Jun 3, 2005 | 01:06 AM
Nobody
Guest
Posts: n/a
Nobody <nobody@nowhere.com> wrote in
news:Xns962481D277C0XZLKJOIDUKLJ098098@24.24.2.167 :
>>> >>on the front.
>> has the HX.
> Nope, EX SE
Going for yet another set of wheels/tires (5th set). This time, they
ordered new wheels/tires from the factory. Of course, now my auto trans
is acting up...slips from 3rd to 4th sometimes.
dampcurse
Apr 13, 2019 04:09 PM
jackanyon
Sep 28, 2016 01:35 AM
Cowboy_Fit
Upper Mid-West Community
Jan 7, 2012 04:20 AM
Wave
Sep 1, 2006 01:09 PM
Daryl Herkin
May 4, 2005 11:16 AM
