2012 Honda Fit Replacing Fuses
Old 08-11-2012, 06:35 PM
proaspen's Avatar
Just got a new Fit. Getting ready for RV touring and will be towing the Fit. I need to pull the radio fuse. Found the fuse, but cannot find the fuse puller. The manual says the fuse puller is located under the fuse box cover located in the engine compartment. Found the fuse box cover and removed it...no fuse puller. Anyone run into the same issue? Discovered where they hid it?
Old 08-11-2012, 06:43 PM
mkane's Avatar
Couldn't find ours either. Used a small pair of needle nose pliers.
Old 08-11-2012, 06:49 PM
proaspen's Avatar
Was thinkin' the same thing...tks for the quick reply. Have a good one.
Old 08-11-2012, 08:10 PM
Dwalbert320's Avatar
It's white....it is installed as a fuse cover to protect the back-up fuse...look for something like a weird looking fuse
Old 08-12-2012, 05:30 AM
Black3sr's Avatar
on the GE 09 it is the white square on lower right beside the red #10 fuse. Just squeeze the ends and pull it out. This is the box under the dash not hood.
Old 08-12-2012, 03:43 PM
proaspen's Avatar
Dwayne: is this in the engine compartment?
Old 08-12-2012, 05:25 PM
No! under your dash on the left side. I will go snap a picture right now BRB!
Old 08-12-2012, 05:45 PM
Black3sr is Correct!
I just ran out there and snapped a couple pics for you.
Pull here. Don't be shy.
The Orange plastic bit over the top left hand corner is just a protector for the back-up fuse. The one for the ECM and Radio. The puller is in the red square with arrow.
Just like Black3sr said squeeze and remove....Voila!
Old 08-12-2012, 06:00 PM
proaspen's Avatar
Dwayne & Black3sr: Sorry for being slow on the uptake. The step by step pics were exactly what I needed, especially the part about pulling and not being shy about it! :-) Thank you so much! Love this forum, ya'll are great!!! Take care.
Old 08-12-2012, 06:52 PM
Nah! no worries. It's friggin scarry to be pulling on stuff. Jeez...I mean...what happens if I screw it up right? it's all good. Whenever I give advice I always point out the scary bits...Today I removed my front grill for the first time to install an emblem and I thought for sure I had screwed my car up for good...turns out it was alright...We are just new at this stuff. I am on your side.
You wanna make my day? snap a pic of your car and post it!
Dwayne
Old 08-13-2012, 04:48 PM
proaspen's Avatar
Dwayne - Well, I wanted to make your day...grabbed my camera and took a couple of pics of my 2012 Fit. Then came to a screeching halt when I couldn't figure out how to upload it. Sigh, a hint pls for this computer hamstrung slow poke... :-(
Old 08-13-2012, 04:51 PM
Wanderer.'s Avatar
Damn it!
I don't care what anybody says, you're a good guy. I would have never found it.
I always just used needle nose pliers
Old 08-13-2012, 07:11 PM
To upload pictures:
Create a free account at photobucket.com
Upload your pics from the computer or directly from the camera.
Then in photobucket when you mouse over the uploaded picture you can select the second option which is to copy the link address.
Then in FitFreak in a post select the little yellow square to insert the pictures link there. Just Paste!
To try it all out before you post you can select to preview your post. But if you screw it up you can always edit your post afterwards.
Old 08-14-2012, 07:12 PM
proaspen's Avatar
Dwayne, Once again..you are the MAN! Here's my jewel:
Old 08-14-2012, 08:50 PM
Triskelion's Avatar
Proaspen and Dwalbert- nice work you guys. This is what fitfreak should be about!
Old 08-14-2012, 09:00 PM
You are so lucky to have a garage! I spy an airforce plate ya Zoomy! I'm a Canadian Sailor.
SilverEX15
07-30-2015 03:30 PM
oneder101
06-15-2015 05:03 AM
fad3r
01-27-2013 04:04 PM
TWGE08
06-10-2009 07:54 PM
sLiVeRwOrM
05-13-2006 11:02 AM
Quick Reply: 2012 Honda Fit Replacing Fuses
