View Single Post
  #3 (permalink)
Old 01-09-2007, 07:24 AM
MINI-Fit's Avatar
MINI-Fit MINI-Fit is offline
Frequent FitFreak Poster
MINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to live
Quote:
Originally Posted by smeister View Post
Any suggestions on new tires for my Base Fit? I'd like some good high performance all season tires. Also, can I go wider than 175/65-14? Thanks.
Your base Fit rims are 14x5.5" and slightly wider tires would be 185/60-14 or 195/55-14.
The stock size 175/65-14 only shows High Performance All Season tires (selection is quite limited).
195/55 and 205/50 sizes don't show any All Season tires. So that leaves 185/60-14 and there are quite a few good tires in that size.
At tirerack.com (ask Jim for more info).
In Ultra High Performance All Season tires-
Bridgestone Potenza RE960AS Pole Position (highly rated at tirerack.com)
Size: 185/60HR14 Serv. Desc: 82H
UTQG: 400 AA A Price: $65.00 (each)
Estimated Availability: In Stock
In High Performance All Season tires-
Michelin Pilot Exalto A/S (highly rated at tirerack.com)
UTQG: 400 A A Price: $78.00 (each)
Bridgestone Potenza G 009
UTQG: 460 A A Price: $61.00 (each)
BFGoodrich Traction T/A H
UTQG: 440 AA A Price: $62.00 (each)
Yokohama AVID H4S
UTQG: 500 AA A Price: $48.00 (each)
Your choice within your budget. If you want the longest treadwear then the high performance All seasons look good. If you drive in wet weather alot the UHPAS RE960AS is quite good.
