View Single Post
  #1 (permalink)
Old 01-31-2007, 08:01 PM
aspecproducts.com's Avatar
aspecproducts.com aspecproducts.com is offline
aspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awards
Send a message via AIM to aspecproducts.com Send a message via MSN to aspecproducts.com
A Spec Cold-Air Intake
A Spec Products
With over 10 years of expereince in the automotive import aftermarket industry, A Spec has been at the forefront of developing new products for new and upcoming platforms such as the new Honda Fit. Located in the heart of Southern California, we are official distrubutors for many high end Japanese aftermarket products from manufacturers such as Volk Racing, Work Wheels, Bride, ARC, Endless etc. as well as other high end non-Japanese aftermarket products such as Recaro, Nardi, Personal etc.
Our tuning philosophy is toward the true heart of performance. We tend to focus on those parts that provide an overall performance increase to whatever vehicle you drive.
This drive for performance is what lead us to the development of our A Spec Cold Air Intake.
A Spec Cold-air Intake Manual Transmission Only
Computer Rendering
Raw Prototype Mock-up
Highlights on Cold-air Intake
  • For Manual Transmission model ONLY
  • 2.75" aluminum pipe,
  • Mandrel-bent
  • Power coated in Black
  • Retains all factory vaccum hose and sensor connection
  • Easy bolt on, installed in 15 mins with common hand tools
  • Washable high flow cone filter
  • No "CEL" Check Engine Check
  • Max. hp gain 5.17hp at 4400rpm (intake alone)
  • Max. hp 97.95hp Max Torque 94.34 lb/ft
DYNO Chart OEM Intake VS. A Spec Cold-air Intake
FOR Axle-back Exhaust please Visit: A Spec Axle-back Exhaust
A Spec Cold-air Intake / Axle-back Exhaust
Highlights on both Cold-air Intake and Axle-back Exhaust
  • Max. HP and Torque Gain over stock (with both intake and exhaust installed) is 8.92hp/10.4lb/ft.
  • Both intake and Exhaust has tremendous gain over stock even at below 3000 rpm, you have no loss on power or torque.
  • Biggest gain at mid range (4500rpm) which is useable for freeway driving and acceleration.
  • Fix the power drop problem at around 3400rpm.
  • Easy bolt on installation, no "Check Engine Light."
  • Sharpen throttle response.
Dyno Chart OEM Intake / Exhaust VS. A Spec Cold-air Intake / Axle-back Exhaust
Overall DYNO
(OEM Fit / A Spec Cold-air Intake / A Spec Axle-back Exhaust / Both A Spec Cold-air Intake & Axle-back exhaust)
Data Chart
Video of Dyno Pulls:
http://www.aspecproducts.com/forums/...deo/Intake.wmv
http://www.aspecproducts.com/forums/...eo/Exhaust.wmv
MSRP:
Cold Air Intake $120
Axle Back Exhaust $210
Axle Back Exhaust Burnt Tip $220
Combo Special:
Combo (intake+exhaust) $300 shipped or CA local pick up
Combo (intake+exhaust burnt tip) $310 shipped or CA local pick up
**Note** California resident please remember to add TAX.
ETA INSTOCK NOW!
- We also have a total of 50 pcs of Intake for MT Transmissions only.
Please send me a PM for stock and pricing.
Thanks
Tuan.
Sponsored Links
