Unofficial FAQ: Ignition corrections
Old Jun 18, 2005 | 10:17 AM
r2000swler@hotmail.com
Guest
Posts: n/a
Re: Unofficial FAQ: Ignition corrections
Michael Pardee wrote:
I don't think the heat is too great for the ignitor. There apparently
aren't
any electrolytic capacitors in it, and those are the big heat sensitive
worries.
The vulnerability of transistors to heat is related to junction
temperature
and to collector voltage. When the collector junction gets hot enough,
the
reverse voltage across it can make the dopants migrate and "blur" the
junction. That spot gets hotter and eventually melts, leading to the
device
being shorted.
But the heat required to melt the junction without the voltage stress
is
much higher than your engine compartment - the melting point of silicon
is
over 2500 degrees F. The silicon chips are typically soldered to the
heat
sink internally, and I have personally soldered a UHF power transistor
to a
large copper heatsink with an acetylene torch.
Mike
Yes, but you didn't put power to it until after it cooled down, and I
bet you moved a lot of air across that heatsink to keep it cool. In
service the
transisotr is switching at least 5A. I have the exact value in my
notes,
and yes it is a fast switch, the transistor is driven completly and
rapidly into full conduction so the Vec is about .5V for ~2mS every few
10s of aMsec.
Not a haeavy duty cydle by any means, but it runs, with "perfect"
heatsinking
to the block at ~195F. Those I measured actualy ran about 210~220F.
Somewhere I have the leakage versus temp from motorola and at +200F
we are getting too darn hot. I saw a Ducati pointless ignition system
that
used a flip flop to switch between 2 transitor to cut the Pd in half.
But
that system was expossed directly to the airstream. Of the people
I know who have had igniter failurs, Honda or Toyota, it has always
been in >90F weather, most frequently in stop and go traffic on the way
home.
Except for one that failed in ~-25F weather on startup. I can't prove
it, but I suspect if we could reduce the temp 20 or even 10 degrees F,
the failure rate would drop "way down". Another failure mode that is
only slightly heat related is the piezo effect on the junction when it
switches.
I had a early JBL switch mode power amp that ate switching transistors
at fairly regular intervals. I had built, and still have, a ultrasonic
down
converter and you could plainly hear the transitors screaming at 40KHz.
I supsect that heat, plus current stress, plus the piezo effect could
explain
most igniter failures. One could always attempt to place it remotly, in
front
of the radiator to breath cool air, but I suspect the lead inductanc
would
kill you and the RFI would be "interesting".
When I needed to align my R2000 SW I needed an "ignition like"
noise source "with harmonics extending up too beyond 30MHz"
I pulled my 1991 Civic under my "long" wire antenna, and adjusted
the noise blanker. Worked much better then the puilse generator
at the shop where I work.
Terry
jim beam
Guest
Posts: n/a
> <r2000swler@hotmail.com> wrote in message
> news:1118859696.926058.152280@z14g2000cwz.googlegr oups.com...
>>One important point is that it looks like Honda skimps on teh heat sink
>>compound. Of course the engine runs hotter then the igniter, so I am
>>not at all sure that adding more thermal coupling will help. I have
>>thought
>>of adding a "heat pipe" tp remove heat from the igniter. I now consider
>>the
>>igniter a subsystem that is doomed to failure. It simply operates too
>>hot
>>for prolonged life.
> I don't think the heat is too great for the ignitor. There apparently aren't
> worries.
> The vulnerability of transistors to heat is related to junction temperature
> and to collector voltage. When the collector junction gets hot enough, the
> junction. That spot gets hotter and eventually melts, leading to the device
> being shorted.
the "blurring" is diffusion - the operating temp doesn't even get close
to melting - but diffusion is powerful stuff and it definitely destroys
semiconductors.
> But the heat required to melt the junction without the voltage stress is
> much higher than your engine compartment - the melting point of silicon is
> over 2500 degrees F. The silicon chips are typically soldered to the heat
> sink internally, and I have personally soldered a UHF power transistor to a
the two factors at play are temperature & time. if the device was
physically big enough and you solderd quick enough, there's no reason
you couldn't do it - afterall, what temperature does a silcon foundry
work at? but you got to be /quick/ if you go to high temps. or best
not at all if you want good service life.
> Mike
jim beam
Guest
Posts: n/a
> aren't
> worries.
> temperature
> the
> device
> being shorted.
> is
> is
> heat
> to a
> Mike
> service the
> notes,
> 10s of aMsec.
> heatsinking
> that
> But
> home.
no proof required - it's true. google for fick's laws and the arrhenius
equation. i too have considered cooling options for my civic's igniter,
even remote mounting in a location where it's not in the air stream
heated by the exhaust or getting thermal conduction from a nice warm
cylinder head, but so far, i've just not had an appetite for the work
involved. i'm also worried about electrical noise. electrically, it
makes so much sense to have the igniter mounted in close proximity to
the coil - nice clean signal, faster switching, etc. but the reality is
that the igniter is kept so toasty warm located where it is, it's always
going to fry in short order, unless you live up in the frozen north of
course, [tegger]. i now carry a spare.
> switches.
> down
> explain
> front
> would
> Terry
Old Jun 22, 2005 | 01:43 PM
Jim Yanik
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in
news:a-CdnfV0hNx07C7fRVn-iQ@speakeasy.net:
>>>sink compound. Of course the engine runs hotter then the igniter, so
>>>I am not at all sure that adding more thermal coupling will help. I
>>>have thought
>>>consider the
>>>hot
>>>for prolonged life.
>> aren't any electrolytic capacitors in it, and those are the big heat
>> sensitive worries.
>> temperature and to collector voltage. When the collector junction
>> gets hot enough, the reverse voltage across it can make the dopants
>> migrate and "blur" the junction. That spot gets hotter and eventually
>> melts, leading to the device being shorted.
> close to melting - but diffusion is powerful stuff and it definitely
> destroys semiconductors.
>> is much higher than your engine compartment - the melting point of
>> silicon is over 2500 degrees F. The silicon chips are typically
>> soldered to the heat sink internally, and I have personally soldered
>> a UHF power transistor to a large copper heatsink with an acetylene
>> torch.
>> Mike
Even the best heat sink does not conduct all the heat away from a
semiconductor junction.The semi junction temp increase is probably faster
than what the HS can conduct away,and having a higher base temp would make
that occur faster.
Jim Yanik
jyanik
at
kua.net
TeGGeR®
Jul 7, 2005 01:26 AM
TeGGeR®
Jul 6, 2005 10:06 AM
TeGGeR®
Jun 6, 2005 03:11 PM
TeGGeR®
Jun 3, 2005 01:06 AM
Chris
May 4, 2005 11:16 AM
