Quote:
Originally Posted by TomiGunz
I got the bars in Friday. I must say, these are cool. Of course these are the first strut bars ever that I've bought for any car I've owned. I will get pics once I figure out how to install them on the front.
Tuan, The fronts came with machine screws, washer, and nuts. I guess we have to get under the fender well and bolt down the front strut bars with the machine screws and nuts?
The rears shouldn't be hard.. Looking forward to putting them on and testing out the performance. When the weather is better here in TX! It's either hot one day or cold the other... Right now,, it's cold!
-Tomi
Yeah the fronts will be bolted down from underneath the wheel well. So you will have to jack the car up front up front, besure to block off the rear tires with some chucks. Then put some jack stands under the front of the car. You will have to bolt-in 3 on each side. 20lbs will be tight enough.
The rears, all you need to know, leave the car on the ground. Pull of the OEM bolt with 14mm (from your stocks). Then put on the bolt we provide you, then the bracket then the OEM on top of the Bracket. After your done with that put on the bar. Tighten them down 20 lbs! And your set and ready.
Anymore question, please let me know!
Thanks,
TUAN @ A Spec.
