02-26-2007, 09:29 AM
Quote:
Originally Posted by TomiGunz
No instructions. It's just simply bolting on bolts and nuts. Very easy to install, but takes time.. Just look at the pics for a guide..
The rear bar has 2 nuts supplied and you gotta take the OEM nut off of the rear strut. Then put the supplied one on. Put the strutbar bracket on, bolt back on the OEM nut. Put the bar on, tighten things up and you're done.
The front has 3 nuts, washer, and bolt. The nuts go under the frame. Use a socket tool for the nut so you can get it under the fender. You dont' have to jack up the car. There's a couple of round, black stickers that you peel off. The bolt goes there. Just line up the bracket, stick the socket tool with the nut on it and look into the hole to make sure the nut is aligned. Once aligned, put the bolt on by hand. Don't tighten until you get all three bolts bolted on. Tighten them up with you're done and bolt on the bar. Tighen up the bar and go take some corners!
If you need detailed photos, I'll be more than happy to take photos for you.
Hey Tuan,, I want some Aspec stickers... what size you have?
-Tomi
Tomi,
Thanks for the info. I think I understand how to install the rear. Seems easy enough. But the front im not to sure. If you could send some detail pics, perhaps with arrows that would be EXCELLENT! I think the part where im supposed to do something underneath the car is confusing me. On my del sol, to install the front strut bar, everything was in the engine bay... Thanks!!
