Quote:
Originally Posted by Toy Yoda
How hard is it to install? Does it come with instructions??
We are currently making the instructions right now.
VOLTAGE STABILIZER:
Install: Power cable will be hooked onto the positive terminal, ground will be hooked up onto the negative terminal, and another ground cable will have to be grounded onto the car's chassis
Tool Required: 10mm socket, rachet, 10mm wrench, zip ties, double sided tape
IGNITION BOOSTER:
Install: Pull the ACC Fuse out, replace with Ignition Booster fuse line, and then ground the grounding wire
Tools Required: Philips Screw Driver or 8mm socker/rachet, double sided tape and your hands!
The Grounding kit does come with the installation manual and is a little bit more challenging to install than the other two items.
Dickson
