Getting closer!Im pretty excited it's turning out pretty good.Here are some pictures of what i have so far.
I tinfoiled and then taped over that.I advise using PAM on the tape,then it just pretty much falls right off.
All the stuff i used.I made sure to have the correct mask.I have gone through about 5 jugs of resin so far.LOTS!!!
Here is the first coat drying under a lamp.It was too cold out and the resin wouldnt dry without it.
Here is a lot of coats later,i changed the design a bit to make the bottom of the box fiberglass instead of wood.Makes it sound and stay together better.
Here is the what i have so far in the car.
That is it i will post more pics when im closer to being done.
