View Single Post
  #114 (permalink)
Old 03-26-2007, 01:13 AM
leonine's Avatar
leonine leonine is offline
leonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to live
clean the lens thoroughly with rubbing alcohol and let dry. I sprayed one even coat from 8-10 inches away back and forth motion 5 to 6 times so it was nice and covered. Then i dryed it with a heat gun but a blow dryer will also be good.
Take the bulb out and rest them on some newspaper or cardboard. No need to tape anything off. I tried to do multiple coats but then the lens got foggy so i scrubbed it off with rubbing alcohol and tried again.
One nice even coat worked best for me.
__________________
Check out the transformation over the past 3 years.
http://www.facebook.com/album.php?ai...7&l=cd5f9d6b0a
