Quote:
Originally Posted by sr20jet
That's a heck of a difference in offset between the 2 factory FIT/Jazz alloys. I'm assuming Ken's car was equipped with the 14" alloys, then he's good with the setup he has right now. Only the tires overall diameter is giving him problems. Go with what I suggested above, try same width tire but lower sidewall ratio, 50 or 45.
I don't think it's the diameter that causing the problem. I think it's the width of tires. I'm still within 3% of the original diameter of the stock 14" alloys. I'll just use up my tires then I'll switch to 185/55/R15 and see if this helps.
