Tanabe Gf210s photos, questions, answers
Old Apr 15, 2007 | 07:35 PM
  #101
pocketrocket's Avatar
How are the df's with camber? doesn't look to tilt the wheels in any, but i was just curious if camber arms would be needed for this amount of drop.
and no, the GF210s are 1.5 f/.9 r... the DF210s are 1.8 f/1.3 r
you SHOULD have a bigger gap in the rear than the front.
Old Apr 17, 2007 | 12:28 PM
  #102
Luichenwai's Avatar
Tanabe GF210 with 16"
So I had my Tanabe GF210 springs installed this weekend. Thanks Logistix!
The drop is perfect. not too low, not too high..
Ride comfort: With any drop, you can't get the same ride quality as stock. I notice a difference but its still good.
Performance: AWESOME. before, I had front/rear strut bars and i can take turns pretty decent.. but it would feel like the top of the car would tip.... now with these springs i just glide right through turns.. I LOVE IT.
Rubbing: NO rubbing 16x7, 205/40 There has been no passengers in the back seat hence no rubbing. Im not sure if it will rub with people in the back.. haven't tried.
We did not cut the bump stops. On 2 occasions, I hit a bump in the road (by accident) and it sounded like my front strut was slamming on something, kinda like a loud THUMP... I'm not sure if its hitting the bumpstops.. But I will see how it rides the rest of the week.
Overall: GREAT. just a TAD bit harsher than I expected, but awesome set of springs.. I recommend them if you dont want that SLAMMED ride.
Pics to come (when weather gets better)
Old Apr 17, 2007 | 02:59 PM
  #103
aznguyen316's Avatar
thanks for the info..is GF the one that doesn't lower AS much right? compared to DF210
Old Apr 17, 2007 | 03:30 PM
  #104
Luichenwai's Avatar
Correct.. As of right now.. after a couple days driving.. I have about 1 1/2 finger gap in the front and back...
Old Apr 18, 2007 | 11:02 AM
  #105
Luichenwai's Avatar
Teaser.. just had to take this shot... Took with camera phone..
We are supposed to get some mmore rain tomororw (thursday), after that maybe friday i will wash the car and take better pics
Old Apr 18, 2007 | 12:00 PM
  #106
Top Ramana's Avatar
when you bottomed out did it seem like it hit it barely hit it or did the shocks need more stroke?
Old Apr 18, 2007 | 12:05 PM
  #107
Luichenwai's Avatar
maybe more stroke... I mean it wasn't a big bump... but it seemed like something under the hood exploaded.. well at least thats what it sounded like... Maybe its the bump stop? I'm usually very careful when driving to avoid the big bumps.....
Old Apr 18, 2007 | 12:23 PM
  #108
Top Ramana's Avatar
yeah sounds like the bump stop you might wanna give it a little trim....
Old Apr 20, 2007 | 12:25 AM
  #109
bigtime13's Avatar
just got my df210's put on and the ride is prety much the same as stock but less body roll. cant wait for the rims now...
Old Apr 20, 2007 | 03:37 AM
  #110
koolkevin1107's Avatar
i see u took my advice and got the gf210's. Great choice. Gotta see dem pix now cuz i bet the britelite's look a million times better on a lowered fit.
Old Apr 20, 2007 | 03:44 PM
  #111
Luichenwai's Avatar
Weather is GREAT... taking pics after work.
Old Apr 25, 2007 | 08:22 AM
  #112
edorwart's Avatar
Luichenwai, What is the offset of your wheels. I was thinking of getting GF210's but want no rubbing issues and I have 16 x 7 - 43mm offset Enkei RPF1's.
Erik
Old Apr 25, 2007 | 08:24 AM
  #113
Luichenwai's Avatar
u should be fine. my offset is +40mm
What size tires are you running?
Old Apr 25, 2007 | 08:43 AM
  #114
avosfit's Avatar
Do you know what the spring rate is?
Old Apr 25, 2007 | 11:24 AM
  #115
edorwart's Avatar
I am running a 205/45/16 BF Goodrich G-Force Sport, it is taller than your tire but .10" short than the factorty 195/55/15 Dunlops.
Old Apr 25, 2007 | 02:35 PM
  #116
Luichenwai's Avatar
Dont know the spring rate. go to tanabe's website for that info.
Not sure if u'll rub or not.. but im guessing no...
anyways.. I love my setup... i dont think im going to upgrade anything else for now... when shocks come out.. I would like to get some.. other than that.. im satisfied.. gotta pay some bills
Old Apr 27, 2007 | 12:47 AM
  #117
its.ryu's Avatar
let me know when you have people sitting in the back. i plan on getting tanabes and 16" rims so i dont want them to be rubbing if i have people sitting in the back.
Old May 5, 2007 | 03:18 AM
  #118
TomiGunz's Avatar
Frequent FitFreak Poster
Tanabe GF210 Installed
First thing first, I did read about the axle popping out of the transmission. Now that kinda pissed me off cuz that's what happend when I pulled out that last bolt on the strut. I got all happy and forgot about it!
It's easy to pop it back in though. Just turn the rotor while wiggling it around and it should take no more than a minute to get it in. It took me about 5 minutes to figure it out, but found out that you gotta leave the whole assembly down, get it the axle locked into the transmission, then give it a little push and it pops right back in.
After that, everything went straight forward. Took me about 3 hours cuz my "helper" kept leaving. So I just did the fronts myself. My wife just happened to get off of work early and was driving to the parking lot while I was working on the rears. So she helped me pull the spring out. Takes less than 5 minutes to do the rears each side.
I found some threads on here and found out that the tools recommended, some weren't needed but was missing what was needed.
Fronts 19mm socket and wrench.
Rear all you need is a 14mm socket wrench.
Anyway,, the drop stance is what I was looking for. Ride quality, it would be nicer if it wasn't so bouncy. I'll get used to it. I like the smoothness though.
I noticed that the stock springs were really stiff. When I go over small cracks and bumps on the street, the ride was really bumpy. Felt like the springs could be a little softer. But now with the GF210s, it smoothens it out.
Taking the corners was pretty fun too with the aide of ASpec front and rear strut bars. Love the way my Fit handles now...
It was worth all the effort. I was gonna take pics but I needed to get it done before it was too late. Started around 8:30pm and was done at 11pm. That's with my friend leaving, and babysitting my 3 year old.
I recommend these springs to anyone who is looking to close the gap on the wheels and fender, and also looking for good performance.
I'll try to get pics tomorrow...
-Tomi
Old May 5, 2007 | 04:37 AM
  #119
u were lucky u got the axle to pop back in easily. It took me and my lil brother almost an hr 2 get the drivers side to go back in. It was funny, the first time it popped out i pushed it back in, then the 2nd time it popped out, it wouldn't go back in.
Old May 5, 2007 | 11:15 AM
  #120
TomiGunz's Avatar
LOL that's gotta suck bro.
So you have GF210s ????
I think I shoulda got the DF210s. I like the drop and all but it's barely noticable. I did the install at night so I couldn't really tell. But now,, I can tell. I wanted the top of the tires to be tucked under the fender just about 1/2 to 1 inch. Then it would look better. Or maybe I just need wheels. Okay maybe I just need money =)
