Quote:
Originally Posted by BigBadMadMan
Ok, how about this then...where does the stock airbox draw air from? Does it have a hose that runs down below the engine like on my Grand Am? If so, I don't see how it could be any worse than the setup on any other car as far as taking in water spray or anything. Also, is this an oiled air filter like a K&N that will be resistant to allowing water to come in?
I think your really wayy over thinking this, becuase if you just get a Drop-in filter then it would be stock piping, box, hose, and etc...
Even if the K&N filter did leak water into the engine, those cheap Fram ones from the dealership would do the same?
As for the OEM airbox draw air form "looks like it comes from the inside the splash guard, and the back of the headlight area"
As for the A Spec intake it sit infront of the Transmission.
Let me know,
Thanks,
TUAN @ A Spec.
