View Single Post
  #1 (permalink)
Old 04-23-2007, 02:10 PM
Invision Fit Invision Fit is offline
Platinum Honda FIT Vendor
Invision Fit is on a distinguished road
Megan Racing Exhaust/Header/Suspension Sale
Invision= Authorized Distributor for Megan Racing
Honda FIT 06+
Model Number : MR-SSH-HF07
Model Number : MR-SSH-HF07 The new trend in performance Sport-Compact vehicles is to become lighter and lighter. The lighter the chassis is the better the power-to-weight ratio will be with whatever powerplant is chosen. The Honda Fit is Honda s answer to this new trend and is prevailing in the market.
Megan Racing has seen this potential and is developing products to get the most out of this Featherweight Fighter. The first way to improve performance of any vehicle is to allow the powerplant to run more efficiently by reducing any resistance before and after the engine.
Megan Racing has developed headers for the new 06+ Honda Fit; constructed of T-304 Stainless Steel, CNC Laser-Cut flanges and smooth mandrel-bent equal length primaries. These headers are the first step to a more efficient exhaust system.
Megan Racing Downpipe
Honda FIT 06+
Model Number : MR-SSDP-HF07 Megan Racing Resonators and Test Pipes offer the ultimate in high-flow performance. Offering substantial horsepower gains in the higher-end of the power band, the Megan Racing Test-Pipes are made of Stainless Steel with a quality polished finish. The Megan Racing Universal Resonators are also made of Stainless Steel and a straight through design, but serve to give your custom exhaust system a more mellow-deep tone while catering to traffic laws and regulations. (Note: The test-pipe is for off-road use only and is not intended for highway use. O2 Simulators may be required if a CEL is triggered.)
- T-304 Stainless Steel
- Direct Bolt-On.
Honda Fit Axle Back Exhaust
Model Number : MR-ABE-HF07 This Axle Back Exhaust is a direct bolt-on to your existing exhaust system. No welding is required, all you need are tools and you can do it by yourself. Perfect fitment, nice strong deep tone, gain performance and quicker response are some characteristics from the result of this product. Constructed of T-304 Stainless Steel and TIG Welded for quality. It is 50% lighter then stock exhaust.
Honda Fit Street Coilover
Model Number : MR-CDK-FIT Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 8kg Front and 10kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Pm for Best Pricing
__________________
Invision Performance, Inc.
sales@invisionperformance.com
Sponsored Links
