FIT-Vendor Sponsored Group Buys and Sales Organize group buys to get discounts. Only Forum Sponsors may post group buys in this sub-forum. Forum Sponsors will have "FIT Vendors" in their user title and have gone through a screening process by FIT Freak staff.
Megan Racing Exhaust/Header/Suspension Sale
Old Apr 23, 2007 | 02:10 PM
Invision Fit's Avatar
Platinum Honda FIT Vendor
Invision= Authorized Distributor for Megan Racing
Honda FIT 06+
Model Number : MR-SSH-HF07
Model Number : MR-SSH-HF07 The new trend in performance Sport-Compact vehicles is to become lighter and lighter. The lighter the chassis is the better the power-to-weight ratio will be with whatever powerplant is chosen. The Honda Fit is Honda s answer to this new trend and is prevailing in the market.
Megan Racing has seen this potential and is developing products to get the most out of this Featherweight Fighter. The first way to improve performance of any vehicle is to allow the powerplant to run more efficiently by reducing any resistance before and after the engine.
Megan Racing has developed headers for the new 06+ Honda Fit; constructed of T-304 Stainless Steel, CNC Laser-Cut flanges and smooth mandrel-bent equal length primaries. These headers are the first step to a more efficient exhaust system.
Megan Racing Downpipe
Honda FIT 06+
Model Number : MR-SSDP-HF07 Megan Racing Resonators and Test Pipes offer the ultimate in high-flow performance. Offering substantial horsepower gains in the higher-end of the power band, the Megan Racing Test-Pipes are made of Stainless Steel with a quality polished finish. The Megan Racing Universal Resonators are also made of Stainless Steel and a straight through design, but serve to give your custom exhaust system a more mellow-deep tone while catering to traffic laws and regulations. (Note: The test-pipe is for off-road use only and is not intended for highway use. O2 Simulators may be required if a CEL is triggered.)
- T-304 Stainless Steel
- Direct Bolt-On.
Honda Fit Axle Back Exhaust
Model Number : MR-ABE-HF07 This Axle Back Exhaust is a direct bolt-on to your existing exhaust system. No welding is required, all you need are tools and you can do it by yourself. Perfect fitment, nice strong deep tone, gain performance and quicker response are some characteristics from the result of this product. Constructed of T-304 Stainless Steel and TIG Welded for quality. It is 50% lighter then stock exhaust.
Honda Fit Street Coilover
Model Number : MR-CDK-FIT Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 8kg Front and 10kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Pm for Best Pricing
Old May 11, 2007 | 01:43 PM
best prices
Old May 11, 2007 | 01:50 PM
megan in stock
Old May 12, 2007 | 01:50 AM
Fit of RAGE's Avatar
How much for the down-pipe with a O2 sim. shipped to Vancouver BC?? My postal code is V7C5W2
Old May 16, 2007 | 05:40 PM
pm sent..........
Old May 16, 2007 | 06:59 PM
George02's Avatar
how much for header shipped to a 85306 zip?
Old May 16, 2007 | 08:48 PM
slowgd3's Avatar
how much for the coilovers shipped to 92683?
Old May 16, 2007 | 09:24 PM
superfatfit's Avatar
coil over
coil over sent to 91732 shit **** it the whole package down pipe, header, coil over, exhaust haha cool thanks
Old May 16, 2007 | 09:28 PM
oh shit! chotto matte!!!!
industry? as in city of industry in california. hahah ill be right there in 10 minutes wait you guys are probably closed already shit.
Old May 17, 2007 | 11:44 AM
moondog's Avatar
How much for a B-pipe shipped to 81621? Thanks!
Old May 17, 2007 | 02:32 PM
adamhassett's Avatar
How much for headers back?
Old May 18, 2007 | 12:46 AM
sam21's Avatar
How much for fit axle back exhaust shipped to 33634?
any sound clips?
what are the size of the outlet(s) of the tips?
Old May 23, 2007 | 02:46 AM
TomiGunz's Avatar
Frequent FitFreak Poster
PM Price for Headers (not the recalled ones) , Pipe, and B section to 76901.
If the headers are the same ones, there's a possiblity that there is a leak, so I don't want that one.
or price for just the Test Pipe and B-Section to 76901
If O2 sensor simulator is available, please include that in the price too.
Thanks!
Old May 23, 2007 | 09:32 AM
thejroisgo's Avatar
PM price for coilovers shipped to 92630, and price if picked up pleeeeeease
Old May 23, 2007 | 04:38 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Price of the B-pipe (if its offered) to 32817.
Old May 23, 2007 | 04:58 PM
moondog's Avatar
Has anyone recieved a response from this seller yet?!!
Old May 23, 2007 | 08:01 PM
sorry, i have been backed up with PM's I will get to you shortly
Alex
Old May 25, 2007 | 08:27 PM
siccmonkey's Avatar
you've got a pm
Old Jun 4, 2007 | 04:51 PM
all pms replied
Old Jun 4, 2007 | 10:53 PM
Posts in the NUUDE
Mine wasnt.
