Noise from suspension on 2001 CIVIC
Old Jul 31, 2005 | 06:45 PM
Henry
Guest
Posts: n/a
It happened on Saturday morning when I went out shopping. The sound is
pretty like the noise made by the door connector without lubricant - "GER...
GER...". I never heard it before in the car. I lift each corner close to the
wheels today by the tool for changing the wheels. I find out that it happens
when I lift the left-rear wheel on certain height.
Could anybody tell me what possibly cause the problem? My front shocks were
changed last year at 48,000km. Current mileage is 66,000km. Is it possible
that another shock leaks and runs out of oil? Can a joint of the suspension
without lubricant produce this kind of noise? Is it a severe problem?
Thanks!!
Another weird thing: I hear the noise coming from left front corner when I
driving the car. But it ends up with the left-rear suspension when I lift
the car.
Thanks again!
Henry
Professor
Guest
Posts: n/a
Re: Noise from suspension on 2001 CIVIC
Sounds like the typical noise a bad bushing makes... a groan/creak.
Professor
www.telstar-electronics.com
Old Jul 31, 2005 | 08:31 PM
hunkman7@excite.com
Guest
Posts: n/a
Have you tried the Chevrolet Cobalt? It offers everything the Civic
has along with more power, more features and greater reliability based
on newer designs. It is thousands cheaper and costs much less to
insure.
> Thanks!!
> the car.
> Thanks again!
> Henry
Old Jul 31, 2005 | 10:30 PM
jim beam
Guest
Posts: n/a
> insure.
why the trolling tonight chunkman? are you bored?
>>Thanks!!
>>the car.
>>Thanks again!
>>Henry
Old Aug 4, 2005 | 12:10 AM
Henry
Guest
Posts: n/a
"Professor" <briangriffey@sbcglobal.net> ????
news:1122846777.608009.296430@g14g2000cwa.googlegr oups.com...
> Professor
Thank you for your help. I found an article which is a proof of your
opinion.
" Honda
Rear suspension noise. Some 2001-02 Civics and 2003 Civic Hybrids can give
off an annoying squeak from the rear of the car when driven at slow speeds
or over speed bumps. According to Honda, one likely cause of the noise is
deterioration in the lower front bushing of the rear suspension knuckle(s).
A revised, more durable bushing (Part No. 52365-S5A-502) is now available to
address the concern.
To determine if the updated bushing will do any good, try duplicating the
problem in the shop by bouncing the rear of the car up and down several
times. If the squeak becomes more noticeable, get the vehicle on a lift and
remove the wheels. Then head for the front attachment bracket of the right
rear knuckle and check the condition of the bushing. The rubber should be
flush with and covering the metal stop ring. If it is, look elsewhere for
the problem. If the rubber is bulging out or overhangs the ring, you've got
metal-to-metal contact between the ring and the attachment bracket, which is
responsible for the noise. Install the new bushing with confidence, then
repeat the diagnostic exercise on the left side of the car."
Later on, I found I made a mistake. Actually, it is the front suspesion that
is making niose. The niose does not happen continuously. It is not loud
either. I callled dealer to try to get some opinion. It turned out that they
only want me to leave the car to their mechanics.
I decided to wait some time until the noise is at least continuous. I doubt
that the mechanics can not find the problem under this circumstance. I hope
I am right.
Thanks again.
Henry
Old Aug 4, 2005 | 08:31 PM
Pars
Guest
Posts: n/a
I'm looking foward to a comparison's between the upcoming 2006 Civic Si and
Cobalt SS. If the new 06 Si is modeled after the RSX Type-S (with comparable
dynamic), it shouldn't be much of a comparisons. Even so, if GM is able to
maintain their price incentives, the SS should still be able to carve out a
market for itself (It's too bad GM's pricing wont give them any points on
the comparison test..since msrp should be similiar between the challengers).
And those two cars are going to be the ring leaders for their more mundane
siblings...So, it'll be an important comparisons test.
Pars
<hunkman7@excite.com> wrote in message
news:1122853416.295235.35420@f14g2000cwb.googlegro ups.com...
> insure.
"GER...
the
happens
were
possible
suspension
> > Thanks!!
I
lift
> > the car.
> > Thanks again!
> > Henry
jy1129
Jul 31, 2020 02:23 AM
hyperfit
Mar 19, 2011 03:29 PM
kingofpicklez
Nov 22, 2009 03:31 PM
dickiez
Jul 31, 2008 03:40 AM
