15x8 Axis Oldskools...fit the Fit?
Old May 25, 2007 | 09:09 AM
007FitNBP's Avatar
see if he'll let you try them on the FIT!
Old May 25, 2007 | 11:26 AM
Whitehybrid's Avatar
i'll do it...i think they are 4x100's...good idea...i don't have my springs in yet cause i just got the car, but i'll see anyway...
Old May 25, 2007 | 11:32 AM
YeeFit's Avatar
Yep. They are 4 x 100, +35mm Offset, 15 x 8".
Axis recommended a 195/50 or 45 series tire.
Old May 19, 2008 | 08:29 PM
rvall004's Avatar
what color are the wheels on the super street picture?...because i know maximm screech makes them in (gloss black with machine lip or machine faced with machine lip) which one is it?
Old May 20, 2008 | 11:17 AM
12o177e's Avatar
its +25. also if u gna drop it get a 45 series tire. 50 series already rubs when u have ppl in the back or hit a slight bump AT stock height still!
Old May 20, 2008 | 12:50 PM
mahout's Avatar
No. See guidelines for aftermarket wheels and tires.
Old May 20, 2008 | 01:18 PM
abscooter's Avatar
I was reading this post last night and know that the shop that I go to is a Axis dealer, I stopped in and grabed a catalog, the Oldskool is a 15x80 +25 offset 4-100.
I also think the wheel will fit on the FIT.
Two thing I thought about.
1st. I have a 16x70 TE37 with a 33 offset. I run a 205-45-16 this gives me a overall diameter of 23.26 inchs and the factory is a 22.93 on the base FIT (175-65-14). I am alittle taller than factory. 195-45-15 gives you a 21.91, so over a inch smaller.
As for the Offset, I have a 7" wheel and the Axis is a 8" my offset is 33 the axis 25. This means the wheel will sit 20.5 mm out toward the fender than mine. With the streacing of the tire and the extra gap. I could see this working.
Old May 20, 2008 | 02:03 PM
samwell's Avatar
hey I also made a thread for these wheels. I also like these wheels but they are just too wide. If you want to put them on there is gonna be a lot of work involving rolling fenders and most likely tweeking camber. Too wide and too low an offset.
Old May 20, 2008 | 07:55 PM
12o177e's Avatar
THEY DO FIT
mad fender rolling is a must though if you're gonna drop!
used to have them but swapped out for NR's cuz my tires kept getting eaten up!!
Old May 20, 2008 | 07:58 PM
Originally Posted by 12o177e
THEY DO FIT
yup........
Old May 20, 2008 | 09:55 PM
dcmcelreath's Avatar
Originally Posted by Whitehybrid
yup........
There you are, I remembered seeing your pictures a while back, I just couldnt remember your user name.
Wheels look incredible on there!
Old May 20, 2008 | 11:31 PM
  #32
that ur xb in ur avy? looks dope...i copped these wheels cause my buddy got the new axis wheels for his xb...his rears are 15x8 with -27 offset 5 inch copper lip...fronts are just 15x7 +0...sooooooo siiiiccccckkkkk....
Old May 21, 2008 | 06:54 AM
  #33
Yes sir it is, thank you! I havent even heard about that low of an offset from axis?? I will have to check that out, its all about the lip.
Old May 21, 2008 | 08:02 AM
  #34
mahout's Avatar
We asked the owner of the dropped Fit we mounted 205/45x16 tires on 16x7 wheels with 45 mm offset to see again how much clearance is available. And my Fit mounted with 205/40x17 tires on my undropped Fit with 42 mm offset wheels.
Sorry, but I go with the original Guidelines for aftermarket tires/wheels. Any less offset or wider tireswill not fit without modified fenders or real narrow tires o n either of these 2 Fits.
I suggest you measure the backspace and find out if you really know what the offset is if you think the wheels in this post work.
Old May 21, 2008 | 10:21 PM
  #35
abscooter's Avatar
When I looked at the Axis catolog, they had a -offset, and even said made for Xb with fender flairs.
Yes will need good amount of fender modification to fit these Axis wheel if you want to lower the car any. The Fit is basically a Hi offset car. for the front, I had to pop the 3 plastic clips out, and flip the inner liner on top of the metal surports and bend up to cut out the rubbing from my TE37 16x7 33 offset with 205/45/16
adam s
Mar 17, 2024 07:58 PM
The Assassin
May 11, 2010 02:33 AM
dpancho
Aug 30, 2008 11:42 AM
samwell
Apr 27, 2008 08:55 AM
OJ Glove
Feb 20, 2008 09:50 PM
