Crawly,
Yes you would need two adapters. I believe you can buy them at Best Buy, or do a seach, you can get them online. There may be a problem. A Best Buy installer told me that the Fit uses a powered stock antenna. They have installed the FM modulator and found the stock AM/FM radio lost about 90% of it's channels. The good news is the Sirus radio works fine. Another problem, I talked to another Best Buy installed who told me he had problems with the antenna adapters, that they didn't excatly fit and had to be "trimed" a bit.
I've done a lot of investagation on this subject since I have a Base Fit without the Aux input and own a Sirus S50 radio. Currently I'm using the wireless transmittion from the S50 but it leaves a lot to be desired. I am waiting for a raining day to tear everything apart and get to the back of the radio. In the mean time if you do a search under Sirus adapters or Sirus Aux, you'll see there are a couple of products on the market that say they will do the same job as the Sirus FM modulator without affecting the stock radio and should match up to the plugs on the radio. They average in price from $75 to $150.
So if you do decide to open up your dash board. Be prepared for some surprizes. If you do it, post your results.
Good luck!
Axel
