Tanabe Racing Development USA
Made in Japan, made in Tanabe. With over 20 years of experience in the development of quality automotive parts for performance application, we take pride in all our products engineered to the strictest of tolerances, produced with the highest quality materials, and made within our very own advanced ISO9001 (International Organization for Standardization) & JISQ9001 (Japanese Industrial Standard) certified manufacturing facility located in Shiga-city, Osaka-prefecture, Japan. Race Tested and engineered to perfection, get an edge over the competition. Fuel the racing spirit!
SSR line up
Old Jun 14, 2007 | 01:42 PM
Tanabe USA's Avatar
FIT Product Manufacturer
SSR line up
SSR utilizes high quality materials with precise technique to continue to manufacture three piece wheels allowing no room for compromise. The same process used over 35 years ago by SSR with the very first three piece wheel, MK1, is still used today and known worldwide. With great support and confidence in technique and quality, SSR is proud to continue to manufacture three piece wheels.
More styles available.
Click here to see list of available wheels.
Wide range of sizes to best fit your vehicle
The three piece wheel that is made up of an outer rim, inner rim, and center disk enable to set the rim width and offset according to your vehicle and specifications in various sizes. SSR’s three piece wheels come in four kinds of center disks to customize your wheel for proper brake caliper clearance.
Super lightweight and high strength *HTM inner rim
The outer rim and inner rim receive the most impact. A high strength inner rim is required due to heavier loads during cornering. By heat treating the inner rim the strength is increased and allowing the use of thinner material. Therefore, we can produce an inner rim that’s high in strength and lightweight at the same time. This heat treated rim has cleared severe tests giving the rim its high quality. SSR’s three piece wheels with a HTM inner rim can withstand high speed corners with great G force while maintaining high strength drawing out the maximum potential of the vehicle.
*HTM means Heat Treatment Manufacture
Forming high quality performance wheels
Taking into consideration the amount of strength needed for each part, SSR uses separate grade of aluminum according to its purpose on the three piece wheels. To make the most out of the materials, each part of the rim is closely calculated and designed for the perfect thickness and balance throughout the wheel. For quality automotive performance, lightweight and high strength is always required. SSR’s knowledge of performance has derived from professional automotive experience to form excellent wheels that are super lightweight and high in strength.
Old Jun 14, 2007 | 09:26 PM
smeister's Avatar
wow
Those SP2 are hot! Nice new lineup from SSR.
Old Jun 15, 2007 | 01:59 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
do you carry anything that will fit an Audi A4? I like the SP1s
Old Jun 18, 2007 | 09:06 PM
marcryan27's Avatar
whats the weights on those wheels? especially the professor ms1R & spR in 16's?
Old Jun 20, 2007 | 04:38 PM
Tanabe USA's Avatar
Thumbs up
Do you have any suspension or brake upgrades?
MS1R 16inch - Starting at 15.65 Lbs.
SP1R 16inch - Starting at 17.70 Lbs.
SP2R 16inch - Starting at 15.02 Lbs.
Old Jun 20, 2007 | 11:44 PM
sLiVeRwOrM's Avatar
All stock. B6 1.8T AWD
Old Jun 21, 2007 | 02:25 PM
Tanabe USA's Avatar
Thumbs up
go to More-Japan.com/SSR.php and click the 'Inquiry' button at the bottom. Fill out the information then we can get you the correct fitment for the wheel that you want.
Old Jun 23, 2007 | 04:17 PM
sLiVeRwOrM's Avatar
before i do that, can you tell me what the lightest 17inch and 18inch wheels that you offer are?
Old Jun 25, 2007 | 12:12 PM
Tanabe USA's Avatar
17inch
SP1: 18.46 - 21.93 Lbs.
*MS1R: 20.17 - 23.99 Lbs.
18inch
SP1: 19.94 - 24.58 Lbs.
MS1: 22.49 - 27.76 Lbs.
These weights are ranging from lowest 17inch and 18inch weights to the highest weight. Specific weights depend on wheel sizing according to you vehicle and specs.
*MS1R available sizes are 15, 16, and 17 inches. MS1 available sizes are 18 and 19 inches.
Old Aug 2, 2007 | 07:05 AM
fairladyz_gt-r's Avatar
I am intrested in the MS1R, 16'' for Fit fitment, Black with chrome, wondering how much it will cost? and whats the weight?
Thanks!
Old Sep 5, 2007 | 12:22 PM
Tanabe USA's Avatar
Thanks!
Hi,
You can find a dealer with the SSR logo by their name and they will be able to set you up with the MS1R's and give you pricing.
http://www.more-japan.com/Retail-Sto...tor-sp-10.html
Specs:
SSR Professor MS1R - 16inch Specs
Old Sep 6, 2007 | 06:04 AM
zeEsoFit07's Avatar
im feeling the SSR SP1's aswell..
Old Sep 8, 2007 | 06:13 AM
Mud_Bone's Avatar
I don't wish to offend, but is the price's given on the SP1R for 1 wheel or 4 wheels? if its for a set of 4 I'm gonna get some , if its priced per wheel I'll have to pass as thats too rich for me blood
thanks
Old Sep 14, 2007 | 07:47 PM
Tanabe USA's Avatar
thanks
Unfortunately the price is per wheel.
Old Sep 15, 2007 | 12:21 PM
Mud_Bone's Avatar
thanks for getting back
Old Sep 17, 2007 | 06:16 PM
Tanabe USA's Avatar
No problem, any questions please let me know!
Old Sep 22, 2007 | 11:51 AM
Bahumut's Avatar
Those prices aren't so bad considering they're true 3-piece wheels.
Old Sep 26, 2007 | 12:25 PM
Tanabe USA's Avatar
SSR was actually the first company to offer a 3 piece wheel to the consumer market. We have also founded many other innovations like Semi Solid Forging and HTM. When you purchase our wheels you are purchasing the best in wheel technology.
Old May 23, 2008 | 02:42 PM
junktea1's Avatar
For the Type-C model, what is the difference between the RS and regular?
Can you get the RS in 16"?
Fit_Dr
Feb 28, 2011 09:45 PM
08jdmfit1
May 12, 2008 09:53 PM
Tanabe USA
Jun 13, 2007 12:28 PM
Tanabe USA
May 23, 2007 12:19 PM
Ricepuddin
Car Shows, Events, and Racing
Jan 27, 2007 11:05 PM
