92 Honda Accord station wagon with EFI start up problems
Old Aug 10, 2005 | 07:39 PM
kathleen williamson
Guest
Posts: n/a
Hello everyone,
I'm resorting to asking for suggestions from cyberspace as I've asked
everyone else I can, and no one seems to know what's wrong with my car,
including the mechanics. I've given up dealing with my local Honda
dealership because I think they gouged me for yrs and performed many
unnecessary "repairs" that weren't a problem when I went in. They
couldn't find anything wrong with it, and now the honest mechanics
around the corner are stumped as well.
As a recap, I have a 92 Honda Accord station wagon with 310,000km and an
EFI system.
So here it goes:
--in warmer weather, there is a tendency for my Honda to have problems
firing up. Frosty, as I've named my car, has an EFI system and not a
carburetor.
--after starting up, the engine just won't catch, ie the tachometer goes
up, stutters, and then drops down to 0 rpms, stalling. The engine
simply fails to fully turn over, .
--this never happens on the first start up of the day. It could happen
once or more during the day, or not at all. When the engine won't turn
over, I might have to try 7 times before it finally fires up.
Eventually it always starts up. If I don't let some time pass after it
won't fire up, and try too soon afterwards, when I try again, I get a
sound like it's flooded, so I need to wait at least 1 min between attempts.
--nothing comes up in diagnostics. And of course, Frosty never acts up
when I take it in.
--the mechanics have looked at the wires, loose connections, coils,
delay in the timing in the electronic ignition, adding fuel injector
cleaner, etc. I wonder if there's a problem with the fuel injector or
fuel pump. A number of yrs ago, my fuel tank was replaced, and the car
has never been the same. Something makes me think, some other part near
the tank was "injured" at that time, and needs to be replaced. My
mechanics are so honest that they don't want to replace anything for
fear it's not what's broken. How refreshing. I'm sure I would have had
2 new parts had I gone to my local Honda dealership...(just in case you
think I'm bashing Honda, I'm not. I would buy a Honda again and again,
but I don't trust the service division in the small city I live in, and
it''s the only dealership we have. They couldn't find anything wrong
with my car when they had the chance either).
--last week, the injector unit was replaced. After filming the start up
problems with a digital camera so my mechanics could see it rather than
imagine what I described, they felt this made the most sense. I ok'd
the repair so I can't blame them. They seem really dejected at not
being able to identify the problem.
--it seems to be related to engine temperature, which could be
aggravated by the outside temps. I don't experience this in colder
weather. It did flare up in Mar after hibernating over the winter months.
--oddly enough, in cold weather, I have just as weird a symptom of
another problem. Instead of stalling after turning over, my engine revs
and revs like the choke is stuck when in Park. Unfortunately the car
has an EFI system. The engine justs vroom, vrooms, without my foot
being on the pedal. Very odd. It happens sporadically just like when
the car has problems firing up in warmer weather. The only way to stop
this is to shift it into gear. Hitting the gas pedal with my foot does
nothing.
So does anyone out there have any ideas what's going on with my car? I
love it, and want to keep Frosty on the road. But unless I get this
problem solved and sorted out, I won't be able to rely on my car.
Thanks for any suggestions you might have.
Please note that I've disguised my email address due to spam problems.
If you post to this NG would you mind contacting me at my work address
as well? I may not get a chance to check the NG each day, but I read
every email that is sent to me at work. Thanks.
kwilliamson@city.peterborough.on.ca
Old Aug 10, 2005 | 08:36 PM
High Tech Misfit
Guest
Posts: n/a
Re: 92 Honda Accord station wagon with EFI start up problems
kathleen williamson wrote:
> Hello everyone,
> EFI system.
> So here it goes:
> carburetor.
> when I take it in.
> nothing.
The warm weather start-up problem most likely points to the main relay.
This is a common (but fairly inexpensive) problem on late 80s/early 90s
Hondas. I am surprised that your dealer never considered it.
As for the cold weather revs, my first guess is a faulty thermostat. My '93
Accord exhibited the same symptom at times, and replacing the thermostat
cured it. However, it could also be the idle air control valve or some
abnormality in the cooling system.
Old Aug 10, 2005 | 10:30 PM
SoCalMike
Guest
Posts: n/a
didnt that vintage also have distributor, ignitor, and ignition switch
problems as well? those are 3 possible weak links in the chain as well.
High Tech Misfit
Guest
Posts: n/a
Yeah, although the OP said that the problem is not there when she starts the
car for the first time on a given day--only on subsequent starts, and in
warm weather. The warm weather factor typically suggests the main relay.
Old Aug 11, 2005 | 11:31 AM
Bruce
Guest
Posts: n/a
I concur with the below posters... Try the main relay. It might be a
combination of things, but this is most likely. There are cold solder
joints in the relay that over time loosen up with vibration. There is a
pictoral how-to on the internet for anyone who is handy with a
soldering iron... can't quite remember where it is, but do a Google
search for "Honda main relay" and maybe "solder".
The main relay is located under the driver-side kick panel.
It's not all that expensive (~$100?) to just buy a new one if you don't
want to get into soldering, etc.
Good luck, and report back if you figure it out.
Old Aug 14, 2005 | 12:31 PM
kathleen williamson
Guest
Posts: n/a
Thanks everyone
I appreciate all your responses. I had the relay changed on Fri--the
garage didn't charge me labour partly because they felt badly about
putting in what appears to be an unnecessary ignitor unit, and likely
because it wasn't an onerous job.
I know I'm going to be anxious for the next while since I was on pins
and needles all summer for the last two yrs. It looks like the weather
is going to be milder this week so maybe my confidence will build up.
Kathy
> Hello everyone,
> EFI system.
> So here it goes:
> carburetor.
> when I take it in.
> nothing.
Old Aug 14, 2005 | 02:00 PM
Elle
Guest
Posts: n/a
Re: Thanks everyone
Had you ever had the ignitor replaced before?
They don't last longer than maybe seven years.
If you never had it replaced before, then for your reference, you are
probably ahead overall financially and car-trouble wise at this point.
> Kathy
> > Hello everyone,
> > EFI system.
> > So here it goes:
> > carburetor.
attempts.
> > when I take it in.
months.
> > nothing.
Old Aug 14, 2005 | 03:34 PM
Michael Pardee
Guest
Posts: n/a
Re: Thanks everyone
"kathleen williamson" <kamandorefusesrefuse@sympatico.ca> wrote in message
news:xQJLe.1595$7R.62637@news20.bellglobal.com...
>garage didn't charge me labour partly because they felt badly about putting
>in what appears to be an unnecessary ignitor unit, and likely because it
On the brighter side, ignitors are a fairly common failure in Hondas of that
age. Replacing it may save you a dead car one day.
Mike
Old Aug 15, 2005 | 03:49 AM
TE Cheah
Guest
Posts: n/a
engine model # ?
Your battery takes time to recover : if you fit ( easiest is to dashboard
clock's connector ) a volt meter, you'll see your battery's voltage fall
& slowly rise.
| I don't experience this in colder weather.
Touch your battery's terminals & sidewalls after >1 hr use, are they
warm / hot ? Any copper sulphate ( white powder ) on the +ve terminal
Old Aug 15, 2005 | 10:32 AM
jim beam
Guest
Posts: n/a
> engine model # ?
> & slowly rise.
copper sulfate is blue, not white.
Old Aug 15, 2005 | 11:30 PM
Michael Pardee
Guest
Posts: n/a
"jim beam" <nospam@example.net> wrote in message
news:IYKdnayhiJZhBZ3eRVn-hA@speakeasy.net...
>> engine model # ?
>> & slowly rise.
Since the post is lead and the clamps are usually lead, lead sulfate would
make more sense.
Mike
wannadoitmyself
Aug 29, 2005 01:31 AM
Fijoy George
Jul 24, 2005 11:53 PM
Goomanjbs
Jul 11, 2005 05:50 PM
les2w
Jun 8, 2005 09:16 AM
ibcarolek
May 4, 2005 11:16 AM
