View Single Post
  #17 (permalink)
Old 06-28-2007, 03:16 AM
toasty toasty is offline
toasty is an unknown quantity at this point
Quote:
Originally Posted by sterVin View Post
does anyone have any experience with this particular model? Would the Fit need the high voltage, low voltage, or is it entirely up to me?
"Choose high- or low-voltage model. High-voltage is perfect if you normally drive shorter distances. Low beams stay on at full power. Low-voltage is best for long distance drivers. Low beams stay on at 24% less voltage to extend headlamp life."
If you want DRLs, get the low voltage model. If you want your low beams on at 100% power, get the high voltage model. Their description would be more helpful if they simply referred to light output levels instead of talking about voltage.
I really don't like 100% DRLs, but that's your call. If the Canadian Fit DRLs operate like those on the USDM Civic, they use the high beam bulbs at a reduced output, which is a better solution IMO.
__________________
DISCLAIMER:
Mod Claymore has deemed that any advice I give may result in a cloud of plastic smelling smoke, and I officially absolve FitFreak from responsibility for said advice or cloud of smoke, plastic smelling or otherwise. If I cite a source, be it another internet site or official Honda documentation, consider the information to be suspect and without merit. Proceed at your own risk, assume the worst, and remember that FitFreak shall not be liable in the event that anything goes awry.
