Quote:
Originally Posted by gettinafit
**update**
Wiring is comming along. Sorry no pictures if you saw the mind working and the mess, you would not to take any second of brain power off of the harness and divert your attention to taking a picture! That plus it is hard to describe in a picture anyway.
Just know that the wiring is comming along, two harnesses are being mated together using Both helms troubleshooting books, one fo the Fit's and one of the RSX. lots of extra wiring and soldering and heat shrinking going on! Maybe this weekend I might touch the engine again and mount it. We'll see!
NOOOOO!! no documentation!?! I'm about to drive to Canada and kick your car!! anyways are you going to have some sensors sending signals to 2 ecus? if you do, are you worried about split signals?... ie. temp sensor, one ecu gets half of the voltage and the other getting the other half, so neither ecu's will have the correct voltage. am i making a valid point here or am i just bringing something up that is nonexistent? anyways good job!
