i have this exact size and offset your looking at and have no problems at all. under all normal driving conditions there is no rubbing at all. but due to the substandard highways here in Nj have to be careful at high speed of dips in the road. will be a slight rub in the rear in that situation only. yesterday had two 200lb plus passengers and 3 5 gallon water bottles and was not rubbing or issues at all. i am at stock height with stock suspension just in case you were wondering. the tire size for this application is 215/35/18. good luck and post pics of your new shoes when you get them on. here is an idea of what it will look like in the stock setup for you.
