I am not sure about powering the components with the headunit, but usually you want to power them with an amp. IMO, you definitely do not need to upgrade the rear speakers. I think the setup will sound good. You can always try it without the amp first and then put in the amp later if you wish. My only concern is that by not powering the components properly, they may get damaged over time?! Can someone please clarify this?
