Problem with lowering
Old Jul 29, 2007 | 01:22 PM
technine's Avatar
I just lowered my fit with Tein S-tech springs yesterday. It was driving good for the first 200 or so km then suddenly after I start to hear some rubbing/grinding noise from the front. I couldn't see anything rubbing near the tires or around the wheel well. What I notice is that if I make a right turn, the noise is gone, but there will be noise if i turn left or go straight.
The noise doesn't really get louder as I drive faster, so I dont think its the wheel bearing. Anyone have similiar issues after lowering? And I have the Sport model with the factory rims on, so I dont think I should have problems with the tires rubbing though.
Old Aug 10, 2007 | 08:19 PM
BlueCell's Avatar
Are you sure it's rubbing on the wheels or is the springs itself not settled right? Sometimes you just need to the springs to settle a little or readjust them.
Old Aug 10, 2007 | 10:21 PM
koolkevin1107's Avatar
bluecell is right the springs sit in the perches of the shock. They must sit correctly or else it'll move around and that's not safe. Go back n check ur install.
Old Aug 18, 2007 | 12:09 AM
solbrothers's Avatar
omg i am having this same problem. lol. kinda scary lol. it is wierd. it only happens when rolling and turning to the left. lol. no matter if you're in a parking lot, or on the freeway. i gotta go back and check that i tightened everything real tight.!! thanks guys !!!
Old Aug 18, 2007 | 02:10 AM
George02's Avatar
heres the deal with that. i have the same problem but figured out wats wrong with it. you kno those little rubber things that sit on the bottom of the springs? well you have to make sure that theyre on correctly or else they will do wat theyre doing
Old Aug 18, 2007 | 02:24 AM
what rubber things on the front?? i didn't realize there was something on the front... hmmm... gotta check it out tomorrow. thanks!
Old Aug 19, 2007 | 10:09 AM
ok. so i went back and tightened everything. (although most bolts were tight) and also adjusted the springs. im not sure what i did, but it fixed it. no more sound!! w00t!!
i think what it was was the swaybar-to-strut bar. those weren't tight enough so there was some binding.
thanks everyone!
ej96hatch
20
Feb 17, 2012 03:14 PM
red08fit
21
Jan 29, 2010 12:01 AM
Batman
Mar 3, 2008 03:36 PM
arsim
Sep 17, 2007 05:41 PM
towelie
Nov 22, 2006 08:54 PM
