-iptuned.com : Rays/Kics Lug nuts in stock
Wondering what this Kics Project magnetic oil drain bolt is for? Every automobile enthusiast should know that an internal combustion engine has lots of moving parts which need to be lubricated to function at its peak performance. Part of proper lubrication is a clean and pure lubricant. Very fine particles of metal are constantly being shed from various engine components due to friction. Over time this metallic ¡§powder¡¨ can be extremely damaging to engine internal, especially bearing surfaces and reduce the life of your engine. This Kics Project magnetic oil drain bolt is an exceptional benefit to your engine in that this loose powder in the oil will eventually work its way past the drain bolt where it will be 'grabbed' by the high powered magnet on the drain bolt and no longer will be circulating through the engine to cause unnecessary wear. You will see the difference every time you change your oil. Each Kics Project magnetic drain plug comes with OEM factory gasket for a secure seal.
Sizing Chart:
- WMAG2 (BLUE) - HONDA/SUZUKI/MAZDA/MITSUBISHI
Kics Project R26 Lock & Lug Nuts. Kics Project Racing Nut Composite features super light-weight thin-wall construction using strong light-weight OEM quality materials. Kics Project designed to ensure best contact with oversized and taper seated. Using the standard 17mm hex key for easy installation. With Kics Project’s innovative design full stud engagement and can accommodate long racing studs. Kics Project Racing Nut Composite is reliable and stronger than aluminum racing nuts, as the lug body is produced by Cold-Forged SCM-435 material. Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish.
Package Contains :
16 Lug Nuts
4 Locks
2 Wrench Adapters
Note: M12 x 1.5mm application: Fits Hondas, Acuras, and most Toyotas, etc.
IN Stock
Kics Project R40 Lug Nuts. Kics Project Racing Nut Composite features super light-weight thin-wall construction using strong light-weight OEM quality materials. Kics Project designed to ensure best contact with oversized and taper seated. Using the standard 17mm hex key for easy installation. With Kics Project’s innovative design full stud engagement and can accommodate long racing studs. Kics Project Racing Nut Composite is reliable and stronger than aluminum racing nuts, as the lug body is produced by Cold-Forged SCM-435 material. Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish.
Package Contains :
20 Lug Nuts
1 Wrench Adapters (Lock can be purchased separately)
IN stock
Kics Project R26 Neo Chro Lug Nuts. Kics Project Racing Nut Composite features super light-weight thin-wall construction using strong light-weight OEM quality materials. Kics Project designed to ensure best contact with oversized and taper seated. Using the standard 17mm hex key for easy installation. With Kics Project’s innovative design full stud engagement and can accommodate long racing studs. Kics Project Racing Nut Composite is reliable and stronger than aluminum racing nuts, as the lug body is produced by Cold-Forged SCM-435 material. Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish.
Note: Titanium Coating Color
Package Contains :
16 Lug Nuts
4 Locking Lug Nuts)
1 Wrench Adapters
1 Lock Wrench Adapters
Kics NeoChrome R40's (BACKORDERED)
Rays 12x1.25 Black Blue RED (regular and Extended in stock)
PM ME FOR BEST PRICES!!
Davethegoat
Dec 19, 2018 11:34 AM
Davethegoat
Dec 19, 2018 08:03 AM
Davethegoat
Dec 19, 2018 07:58 AM
FIT-tles Worth
31
Aug 17, 2014 05:55 PM
