View Single Post
  #45 (permalink)
Old 08-17-2007, 03:05 PM
aspecproducts.com's Avatar
aspecproducts.com aspecproducts.com is offline
aspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awardsaspecproducts.com should get some awards
Send a message via AIM to aspecproducts.com Send a message via MSN to aspecproducts.com
Hey guys,
The reason why we make the intake tube shorter from throttle body, to avoid any rub or clucking from the tube and the throttle body, also give room for engine to move around from torque, or quick shifting, and dumping the clutch. It seems really spaced apart but its not, its made for engine movement.
The other thing about the brackets, it is a tight fit. In order to put it one. You need to add tension to both brackets. Besure to only hand tight by hand before shooting it into the bolt, to avoid any striping. And before I got, the bolts are 10mm.
Thanks,
Hope this will help better understand the product better.
Tuan @ A Spec.
