Piggy back ecu or apexi A/F computers?
Old Sep 16, 2007 | 10:48 PM
ride_the_pony69's Avatar
Yo, I am thinking of doing some N/A mods to my fit right now like intake, header and exhaust. I want to get the most out of the parts so I want to add some kind of ecu or apexi air fuel controller. Is getting a greddy emanage or hondata reflash worth it or would I be better off getting just something like an apexi air fuel controller and save some money at the same time?
Old Sep 20, 2007 | 12:55 PM
DynamicFit's Avatar
Both the emanage and apexi afc are piggyback fuel controllers. There are subtle differences between them, including amount of tunability and equipment they are packaged with. They both modify airflow signals to adjust the amount of fuel being applied at different rpms. You should also check compatibility when buying aftermarket air fuel controllers before simply buying them, because although those units are considered universal there are cars out there that will try and cancel out the changes that you make to the AF. My $0.02.
Old Sep 21, 2007 | 08:01 PM
Sugarphreak's Avatar
Push My Button
I wasn't aware there was anything availaible other than piggy back systems for the Fit at the moment.
Old Sep 21, 2007 | 08:17 PM
cojaro's Avatar
#003 of Siphon has a wiring diagram for adding the Apexi Neo AFC to the USDM Fit.
Old Sep 23, 2007 | 12:13 AM
jtanoyo1's Avatar
I went with Dastek Unichip. Combined with drop-in K&N high flow filter, Spoon throttle body, Spoon header, a larger downpipe and a Trust Beatmax-Ti exhaust system, I gained +10hp and over +20lb/ft torque from standard on 15" wheels and auto transmission.
Old Sep 23, 2007 | 09:14 AM
rickarch's Avatar
try Camcon-H from Power Enterprise. can set VTEC engagement point, A/F ratios, cam setting. purpose-built piggyback for Honda cars . click here for more info http://www.powerenterpriseusa.net/products/electric/camcon/camcon_honda.html
Old Nov 11, 2008 | 11:50 AM
Bassplayer's Avatar
Wow that sounds like a good gain. Anymore info on this Dastek Unichip? did you actually dyno your car?
Old Nov 11, 2008 | 02:45 PM
cojaro's Avatar
Is that bhp or whp? And 10%+ hp and 20%+ lb-ft is quite the gain. Let's see the dyno sheet, bitte.
MISTERHONDA
Feb 4, 2017 04:42 PM
jdmspoonfit
Jun 26, 2009 01:45 AM
1990hondahf
Aug 19, 2008 04:18 PM
Batman
Mar 6, 2008 03:48 AM
REXXXXXXXXX
Jan 14, 2008 01:57 AM
