View Single Post
  #7 (permalink)
Old 09-20-2007, 04:48 PM
JamesBizzle JamesBizzle is offline
JamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to liveJamesBizzle relies on Rep Points to live
Send a message via AIM to JamesBizzle
Yeah, like chris said, it's very similar to Skunk2's but instead of raising up the original bushings, they are replaced with aluminum bushings that are about 1/16 of an inch taller then the OEM rubber/plastic bushings. I honestly can't tell the difference in the height, but can tell that the throws are shorter and more crisp. Also, with their Kit you have the option to go back to Stock throw/height if there ever comes a need to. This is not possible after installing Skunk2's Kit.
And to answer your question, no the lever is not replaced.
