View Single Post
  #1 (permalink)
Old 09-25-2007, 07:10 PM
smeister's Avatar
smeister smeister is offline
smeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to beholdsmeister is a splendid one to behold
Send a message via AIM to smeister
DIY: Taking apart the headlight
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself, nor FITFREAK.NET endorse, recommend, encourage nor take any responsibility for the outcome of someone else doing the following. You follow these steps at your own risk!
This is just the steps I took to take apart my Fit's headlight. It was very easy and on my first attempt (headlight was not warm enough) I mest up the black plastic a little when I was frustrated. My second attempt things went smooth like butter!
Instructions:
1. Prepare the headlight by taking off the small dark grey nipple on the black of the headlight and also the three screws you see on the back of the headlight.
2. Preheat oven to 200F. I actually had mine at 210F and mine is a gas oven. It all depends so I would recommend 200F or less.
3. Once the preheating is complete, turn off the oven, and place the headlight inside the oven on top of a tray with a baking sheet.
4. Let sit for about 10 minutes. I had mine in for 11 minutes and then took it out.
5. It should be warm enought so that you have to use a mitten for the first few minutes.
6. Pry around the back of the headlight with a screwdriver or butter knife. Both the black sealant and black plastic will stretch nicely when it is warmed properly.
7. Once you have seperated the plastic and lens you have enough leeway to use your hands and pry the two pieces apart. Take your time and you will see the black sealant stretch. I used a screwdriver to seperate it once it was stretched out and kept pulling the lens and plastic apart and repeat until the whole thing was off.
8. If you are having a hard time, put the headlight back in the oven and let the sealant soften up.
Here are a few pics so you get the idea.
Where to start prying.
Slowly prying the headlight apart.
If you need instructions on how to paint the headlights please go to this link.
http://www.fitfreak.net/forums/fit-l...eadlights.html
If you need instructions on how to put the headlight back together please go to this link.
http://www.fitfreak.net/forums/fit-l...-together.html
__________________
I do HID Retrofits!
*** HID Retrofit SERVICES ***
DIY: HID Retrofit with FX35 Projectors
More HID Retrofits Competed
My Honda Fit DIY and Reviews BLOG
FOR SALE:
$1200 shipped - Clear Lens Retrofit w/ OEM FX35 HID Kit
$600 firm - Miata BBS 15x6 4x100 wheels
Sponsored Links
