View Single Post
  #8 (permalink)
Old 10-03-2007, 01:13 PM
TOOL's Avatar
TOOL TOOL is offline
Administrator
TOOL has disabled reputation
Send a message via AIM to TOOL
Quote:
Originally Posted by manxman View Post
Yay, Earthmover84 Randy- way to go! Come on guys, out of 26 names on the original list, surely some of you were serious? From past experience with a different brake manufacturer (Stainless Steel Brakes, New York) and a different vehicle (Ford Bronco II), I can promise you the following: You'll never do a rear brake job because discs/pads last 2-3 times longer than drums, you'll have an e-brake that can stop your car all by itself, and hold the car on ANY hill by itself without the auto trans. in park, and install time will be under an hour (you don't even have a rear axle/differential to take apart for installation), and your ABS will work even better than it does now.
I can't say this is fact, but my prediction is that this kit will INCREASE resale value because of better brake performance than stock, and the absence of maintenance/repair.
If you are late on car payments because of finance problems, then not being able to go through with this is understandable. Otherwise, you can't beat this deal that Chris worked out for us. It's a Can't Lose opportunity.
Nice write up Dave, that really really made me want to buy it...
__________________
- KillerFit #12 -
Honda Fit Forums Administrator
www.myspace.com/cellofaneband
