Adjustable front swaybar?
Old Oct 12, 2007 | 10:15 PM
Skimmer's Avatar
Is anybody making an adjustable front swaybar for the Fit? And no, I don't mean a strut tower bar, but a swaybar: the bar that connects the lower control arms together and keeps your car from leaning in corners.
I'm looking for an adjustable bar to use in autocross, one with different holes in the ends for adjustability, or a sliding coupler on the ends.
Lemme know!
Old Oct 13, 2007 | 11:33 AM
manxman's Avatar
Lemme know!
Probably not- one of those things that will take forever to come to our market. You might check with Addco in either North or South Carolina (can't remember which state). They have been making after-market sway bars for everything from sports cars to trucks for 40 years or more, including adjustable end-link bars.
Old Oct 13, 2007 | 06:03 PM
nttdemented's Avatar
If I recall correctly Blox has an aftermarket sway bar for our cars, its 2mm thicker and has polyurethane bushings. Search for it in the Battlendless vendor forums, I think I saw it there.
Also, one coilover kit in particular, the T1R B-Max set, has adjustable sway bar endlinks that would allow you to adjust the stock or aftermarket swaybar.
Old Oct 13, 2007 | 11:34 PM
Skimmer's Avatar
Thanks for the replies.
No luck on Addco. They don't list anything for the Fit:
http://www.addco.net/Honda-Jensen_He...bars.htm#Honda
Found this on the T!R B-Max kit. It includes nothing about swaybar adjustment (but it looks sweet otherwise!):
A&J Racing :: Suspension & Brakes :: Fit/Jazz (GD3/4) :: T1R B-max 52 Damper - Honda Fit 07-up GD3
But I did find this from an ad in Grassroots Motorsports magazine:
Powergrid, Inc.
They offer adjustable swaybar endlinks for the Fit. These don't allow you to adjust swaybar stiffness, but they do allow you to dial out preload on one side -- or to create preload on one side if you want that. This looks like the best thing out there at the moment.
Anybody used this kit?
Old Oct 14, 2007 | 01:53 PM
For some reason the endlinks aren't displayed in the aj-racing.com pics but if you look at the thread about them in the AJ-Racing vendor forums you can clearly see them installed.
NoxiD
Oct 30, 2013 04:59 AM
mikejet
Jan 29, 2009 05:28 PM
F'it_ImFromTx
Sep 1, 2008 10:31 PM
F'it_ImFromTx
27
Aug 25, 2008 12:43 AM
tiF adnoH
May 26, 2006 11:03 PM
