View Single Post
  #8 (permalink)
Old 10-16-2007, 12:02 PM
none none is offline
none is on a distinguished road
Quote:
Originally Posted by Apex77 View Post
Hello all,
Okay, I'm going to try to start this thread so the information will be clearly available for everyone. What I'm trying to do is get a list of suspensions that WORK! Not those that Rub. This information is scattered all over the forum and is inconsistent and hard to find
So here is how it should be done:
List the following:
  • Wheel type, size, offset, etc
  • Tire size, type, etc
  • which Springs or coils and the drop
  • Add one picture if possible
**IF YOUR SET UP RUBS, PLEASE DO NOT LIST IT**
Even if it ONLY rubs with 4 people in the car. That qualifies as rubbing in this thread.
If you have never had that many people in the car, so you don't know if it will rub or not, then please indicate this.
If you had to roll fenders to stop the rubbing ..DO NOT LIST IT
Ok .. lets get it going
(Perhaps a moderator can make this a sticky if we get enough quality info in this thread)
Here let me help you...
Re-read the mans post and see what part applies to YOUR last post.
It should not be too difficult.
The idea, in case you did not get it, was to find out what combo WILL work. Not your opinion of what little rub becomes no rub!?
We already see yours does not apply to NO RUBBING.
Mine for instance with 195-50-16's 45 offset 16x6.5 rim on stock suspension does not rub! Even when I had it loaded to the max during a recent move (suspension was compressed about 3" in the rear and over 2" in the front) I went over speed dip (oops) and bottomed the suspension with no rubbing AT ALL.
So, now do you get it!?
