Eibach Springs - Sportline and Pro-Kit suspension kits - $215 Shipped
Old Oct 16, 2007 | 04:43 PM
aallbbeerrtttttt's Avatar
dsffsfafaqf
Old Oct 16, 2007 | 05:03 PM
TOOL's Avatar
Alberts back!
I have a quik question, how much do these lower then Fit?
Old Oct 16, 2007 | 05:05 PM
Originally Posted by TOOL
Alberts back!
The Sportlines lower the car 2.0" in the front, 1.8" in the rear
The Pro-Kits lower the car 1.6" in the front, 1.3" in the rear
I don't have pictures personally of the cars lowered, but I know there are a couple out there, so feel free to post guys!
Old Oct 16, 2007 | 05:09 PM
Biven5's Avatar
What's the shipping cost to 68521?
Old Oct 16, 2007 | 05:13 PM
Shipping should run about $20
Old Oct 28, 2007 | 05:09 PM
dank24's Avatar
so an upgraded dampers/struts are not really necessary with these springs? It will play out for a few years?
Old Nov 1, 2007 | 01:07 AM
Upgraded shocks/struts are recommended, but not required for a while. As with all lowering springs, lowering the car puts more stress on the shocks/struts than compared to factory parts. Although these lower the car, the factory shocks/struts handle it quite well. I'm on a set of lowering springs, progressive rate which is same as Eibach, and has the same drop height. I've been on them for over a year, and i've daily driven it every day. I've put about 25k miles on it since i've installed them, and till this day it rides like day 1. I'm sure later in the future when companies like Tokico, KYB, or Koni produce upgraded shocks/struts meant for lowering springs, paired together would make a great match.
Old Nov 14, 2007 | 03:55 PM
Bump!!!!!!!!!!!
Old Dec 31, 2007 | 07:41 PM
07fitsport's Avatar
i would think that with the lowered springs no matter waht brand or drop that you could go to somewhere like pepboys, autozone, advance auto or an local auto parts store and pick up a strut and shock that is approx the drop size shorter...
Old Dec 31, 2007 | 07:58 PM
Fit of RAGE's Avatar
how much for shipping to Vancouver BC? my postal code is V7C5W2. Thanks!
Old Mar 3, 2008 | 11:38 PM
Shipping to Canada is an additonal $25.
Old Mar 27, 2008 | 10:06 AM
gonang's Avatar
shipping to 32810?
Old Mar 27, 2008 | 10:51 AM
eldaino's Avatar
Alberts back!
check out the spring rates comparison thread tyler, there is some good info in there, including a bit that shows that the eibachs actually lower quite a bit more than advertised.
Old Mar 27, 2008 | 01:35 PM
Skibum's Avatar
This is my car with the sportlines. Pic taken 10 minutes after install - not settled yet.
Old Mar 31, 2008 | 02:20 PM
Shipping to the east coast is $20
Originally Posted by gonang
shipping to 32810?
Old Mar 31, 2008 | 02:22 PM
looks nice!
Old Mar 31, 2008 | 09:00 PM
B-Rock landers's Avatar
what about the pro street i need to see what the drop looks like on stock fit or on 16 if any one has that done
Old Mar 31, 2008 | 11:52 PM
YeeFit's Avatar
What are the spring rates of the Pro Kit? front/rear?
Old Apr 1, 2008 | 01:19 PM
Here is what Eibach says.
Originally Posted by www.Eibach.com
What is the spring rate of the Pro-Kit?
Only simple linear springs have a spring rate. A sophisticated progressive Eibach Pro-Kit spring has a load/deflection characteristic. The special design parameters are only accessable through Eibach Desk-Tech Database to Eibach´s exclusive partners.
Old Apr 1, 2008 | 02:01 PM
Fit_Noob's Avatar
I know this is such a noob question, but why does it lower the front more than the back, don't you want an even drop??
