Rear Plate Rattle
Old Oct 16, 2007 | 09:54 PM
LDO's Avatar
LDO
Rear Plate Rattle
OK,
saw a thread yesterday about the rear plate/frame rattling and a couple of products were recommended.
Someone please point me in the right direction!!
Old Oct 16, 2007 | 11:23 PM
radareclipse's Avatar
License Kit
Apply this on the backside of your plate and you should be good to go.
Only $15.
Old Oct 17, 2007 | 11:48 AM
manxman's Avatar
Or, if you already have a Pop-Rivet gun, just drill a hole in each lower corner of your plate frame, through the plate itself, the size of whatever rivets you happen to have on hand 1/8" or 3/16" work perfectly. The rivets will bind the plate to the frame and rattles are no longer possible. Use aluminum rivets to prevent rust.
I did this to my rear plate/frame simply because the rattle, whenever I closed the rear hatch, was annoying.
Old Oct 17, 2007 | 12:27 PM
LDO's Avatar
LDO
Good thinking manx!
Not sure why I didn't think of that. I fix the problem PLUS, I get to drill holes and rivet stuff!! SWEET!
veazer
May 11, 2015 03:24 PM
ZXRider
Aug 19, 2010 05:30 PM
polokid69
Oct 16, 2009 06:49 PM
hqly
Nov 24, 2008 04:32 PM
davis61381
Sep 20, 2008 10:01 PM
