Testing with G-Tech Pro
Old Oct 30, 2007 | 02:19 PM
Fit of RAGE's Avatar
Originally Posted by ciburri
Guys, I'll admit I am bias when it comes to G-Tech.
My best man is a friend with Jovan, the inventor of G-Tech.
I personally do not have the unit, but I can tell you the man has some serous schools behind him and is certifiable car nut. Cars in commercials are his! Supra and M3!
Unit does not tap into anything except cigarette lighter socket for power.
It measures g forces in real time and performs factual calculations.
G forces measurements in real time replace tire wheel with sensors attached or optical lights. That is stone age now. When they say in commercial that "others tested it and now test with it" is not a BS! That small device due it's operational principles blows away many sophisticated devices and their shear complexity which adds margins of error. Dyno's are great but figures vary due to it's efficiency. Driving a car on rollers does not factor in real driving with wind resistance, ram air induction, intercooling,.......... This gadget does! Big fans on dynos prevent overheating, but do nothing for efficiency.
The only biased information you need to enter is vehicle weight for horsepower calculation. Do it at the weight station and adjust accordingly for fuel loads and you will be right on the money. Do not cheat otherwise calculation will be off! If you do not feel like disclosing your body weight, just include it in the weight of the vehicle and fuel! LOL!
So what you're sayings is that it's relatively accurate??
Old Oct 30, 2007 | 02:30 PM
ciburri's Avatar
IMO, the unit with smallest margin of error.
Right out of the box it will give the most correct acceleration, braking and G's measurements.
Fact - temperature, air pressure, wind direction, vehicle and individual's driving runs are changable variables - unit's calculation of G's in real time is consistent. It never changes.
To keep your measurements of added parts as accurate as possible, do two runs in opposite direction and calculate the average. Also invest in a digital thermomether with barometer. Try to make your runs with different set up's under the same weather conditions. If you can, run different set up's within minutes of each other. I say if you can, because it is not like header can be pulled in and out like air filter options.
Ohh, one more thing. Adding parts on top of other parts will sometimes hurt performance. Sometimes parts are not made/tested in developments with each other! Keeping a good balance between intake and exaust will do more for performance and driveability than going extreme with one and not the other. Only self variable parts can give you top and and bottom end torque on NA engine. With that said, I can't think of any at the momet! LOL! The smaller the engine the greater the problem -no torque! We are forced to set goals on what we are trying to tune it for. Either good low and mid end torque or top end horsepower.
You are going in right direction! You have the right tools to keep testing! Keep going and you will find what best works for you!
Old Oct 31, 2007 | 02:13 PM
tonyd3773's Avatar
Smile G tech
Question....where can I purchase this G-Tech guide tool? I would like to monitor my Fit's actions as well! Thx
GD3blaze07'
Old Oct 31, 2007 | 04:42 PM
ciburri's Avatar
Since you are in SoCal you even have an option to pay them a visit in their offices in Santa Monica, check the unit for yourself and talk to them in person!
GTech-Pro Company Information
Old Oct 31, 2007 | 05:32 PM
tonyd3773's Avatar
Kool
Hey man...thanks for the information.
GD3blaze07'
BKKJack
May 9, 2015 09:20 PM
blackndecker
Sep 30, 2010 03:21 AM
Giggles
Nov 26, 2008 01:49 PM
Bennet Pullen
Nov 20, 2007 10:15 PM
Gil554
May 3, 2007 07:37 PM
