Is it rubbing in front, back, or both?
I guess that's good to know, if a little sad. Sure would be nice to stuff a ton of tire under the Fit, but there's not much real estate to work with by it's nature. 45mm offset is too much to work in Stock, but obviously OK for some other classes - 1/4" is the max I can deviate from stock offset, and that's only 6.35mm. Call it 6.0 because they don't let you round up at all... 49mm is the max I can go.
